Slow acceleration - Pls Help
C240 2004
Hi all,
My father has a C200K 163hp, 2003. It has 52,000km. Months ago I drive it and feel it has a slow acceleration than before when it is new. I had changed air filter, fuel filter and clean the fuel tank: it improves a little but not as my expectation.
Why should I do then ?
Originally Posted by abud
try to change your exhaust, it will give more power for ur benz.
Good luck!
Good luck!
Have you tried an ECU reset?
I'm assuming your father drives quite slowly. The ecu will adapt to that and shift sooner and what not.
I think instructions on how to reset the ECU are on the forum.
Originally Posted by ricky.agrawal
That might or might not fix the issue. I doubt his problem lies with his exhaust system -- although it might probably not.
https://mbworld.org/forums/showthrea...ight=reset+ECU
Do you think your MAF might be going bad?
https://mbworld.org/forums/c-class-w203/115277-list-faults-occur-after-disconnecting-battery.html
Read that afterwards.
C240 2004
Originally Posted by AMGizZLe
Did you change the engine oil? Mine made a difference when I switch to Mobil 1 0w-40 synthetic. Which is recommended by MB.
