Remove Doorpanel
Old May 11, 2006 | 10:03 PM
rlee02135's Avatar
2004 C32 ///AMG
Remove Doorpanel
Anyone know how to take apart the rear door's panel?
i was changing the doorpins while someone was driving, and the thing fell in.
Old May 11, 2006 | 10:27 PM
EV0LVE's Avatar
F10
i would be extremely cautious to do that, there's an airbag in there. if there are no problem with the pin being inside the door panel, i would just leave it there and get a new pin. good luck
Old May 11, 2006 | 11:24 PM
raymond g-'s Avatar
99 E320
heh heh.....you sure it fell in? or did someone press the LOCK ? (oh, i
guess the auto lock feature kicked in = while in motion)
Old May 11, 2006 | 11:34 PM
ChaRgeC230's Avatar
05 c230 SS
to take it off there will be 4 screws. use a flat head and pop the SRS badge out and theres one screw(its the star kind forgot wat size though). then on the edges there will be one screw thats holding the plastic thingy close to the hole?? the other two is inside the handle. again use the flathead and pop off the handle cover. and the door should pop out. kinda hard to explain but hope this helps u. takes me 2 mins to get mine off. oh yeah remember to unscrew your lock pin.
Old May 11, 2006 | 11:52 PM
raymond g-'s Avatar
99 E320
here is video of W210 front panel removal. quite easy, as described by CR.
hope W203 is similar. try not to use screwdriver to pry anything if you can.
use plastic spatula or something like hard rubber with a tough rubber edge.
note the MB tool. iow, be careful.
still, maybe easier/quicker to just manipulate the door un/lock and fish the
puppy out. it can be done....use the Force, Luke.
Old May 12, 2006 | 12:47 AM
W0n6_3d4n's Avatar
C200K (w204)
Take a picture of the door panel and i'll tell u the screw location, it's easy, airbag is attached to the metal frame so it won't be affected. Just make sure when u slide the panel back nothing potrude the air bag way. Someone did that to my door (i think the dealer) and it has a permanent bulge, mighty ****.
Old May 12, 2006 | 02:56 AM
patrick_y's Avatar
2006 E55 and 2002 E320
That's a very good and descriptive video.
Thanks for sharing it!
