Stuck in the middle of changer install
Questions:
1. Outboard of the screw holes I see metal loops that I assumed were part of a spring mechanism. I have revised my assumption and now believe that these are the clips that I should have removed in the first place. Is this correct?
2. If 1 is false can someone give me a better understanding of where the lower trim clips are?
3. I'm assuming that if I can unclip the bottom of th console trim I will have enough access to the back of the ashtray to retrieve the screws/clear the hinge. Is this correct?
4. If 3 is false, is there a way to completely pull out the ashtray (I've already removed the insert) to make removing the console trim easier and so that I can retrieve my errant screws?
Any assistance would be greatly appreciated.
There aren't any screws on the bottom. If you open the ash tray about 50% and look into the gap you should see a 'T" shaped wire clip on each side. Use a flat screwdriver to push these down to unclip.
