is it the fuse? (cigarette lighter doesn't work)
Old Jun 9, 2006 | 06:16 PM
stoneweed1's Avatar
my radar detector doesn't power when connected to the cigarette lighter, but it does on my other vehicles, so its not the radar detector.
where is the fusebox for the cigarette lighter so that i can change it?
thanks
Old Jun 9, 2006 | 06:18 PM
SFoRZA's Avatar
C32 AMG 2002
Old Jun 9, 2006 | 10:27 PM
TNblkc230wz's Avatar
C320 Coupe
There is a fuse panel in the dash behind the left side cover of the door. On the coups, the panel doesn't look removable, but it will come right out with a flat tip screw driver. It is the end panel that is against the driver's door. Inside this compartment is a folded sheet of paper listing all the fuses and their numbers. There are three fuse panels that I know of. One by the left front strut, one by the first aid kit in the trunk and the one in the left side dash. The lower number fuses are in the trunk, middle numbers to about 42 are in the dash and higher numbers in the engine compartment.
