Car vibrates at 75miles /hour and above on freeway!
MB C240
2 days ago i realized that my car starts to vibrate after my speed gets up to 75 miles and above on freeway. Everything seems to be ok on local. my coworker told me i might need tires change and do alignment. Do u know if that is the case?? My car is using H&R cupkit, normal for 1 year since last week. after my car reaches the speed 75 miles per hour, the passenger chair next to me is obviously vibrating and i can feel my chair too.. pls advise, thanks!!
2015 E550 Coupe, 2012 E350 4matic Sedan, 2016 fully blown out custom camaro 2SS
That would be my best quest, it would'nt hurt to start there first...............
Goodluck.......................................... ...............................
I have the same problem with my 01 c320. I put new rims and tires but it still vibrates at 80mile or above. But sometimes it does not vibrates, so I dont think its a tire or rim issue. I dont want to take it to the dealer as they are going to charge me a lot. It is not causing me any problem so I am driving it as it is.
Mercedes GLK 350 2012
I would say first do rotate and balance
this would have a chance to check on the wheel,
brake disc, suspension, and axle.
The worst case would be axle problem
But check everything, don't just do balancing
cause when do balancing, the wheels have to be out,
so you can check on the axle, see if the axle is moving
cause you don't want to go back again and again with the same problems.
