Turn signal??
Old Jun 21, 2006 | 01:05 PM
bxtc's Avatar
C230 Kompressor sportscoupé (2001)
Turn signal??
My front left turn signal stopped working on my c230 sportscoupe today, i tried everything, changing bulbs etc wouldt work at the left side. Testing same bulb at right side worked perfectly..
I went and bought a new set og "bulb holders" (The thing you put the bulb in before you "click" it into your car) or what ever they are called to be sure it wasent there the problem was, but even with them the left side still wont work.
Do i have some kinda fuse problem ? In top of that my Cruise control is still out and my car is in some kinda limp mode, all though it change gears normally.... Perhaps i have some kind of electrical problem that does all this?
Anyone ??
Thanks a alot!
Old Jun 21, 2006 | 01:34 PM
harpz's Avatar
check the fuse box, may be they're seperate for left and right side
Old Jun 21, 2006 | 02:27 PM
bxtc's Avatar
Checked...
I checked that, its the same fuse
Old Jun 23, 2006 | 10:58 AM
bxtc's Avatar
Works again
Took it to the dealer, they fixed the problem, its was some kinda electric error...
Old Jun 23, 2006 | 11:22 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
that use to happend on my car the way I fix it was to disconnect the battery wait 2 min then plug it back in.... walla it works again. I got new bi xenon so never happend again
