Radio / Audio dead after battery problem
Old Jul 30, 2006 | 07:23 PM
CarlssonPower's Avatar
2002 C240
I searched but didn't find an answer, and I didn't see this issue under the "List of faults that occur after disconnecting battery... " thread either, sorry if repost.
anyway, this is what happened. My battery was dead this morning, after I jump start the car, both the sunroof and radio went dead. I searched the forum and found the method to reset the sunroof and was able to re-activate it. Is there a way to reset the radio as well? I found a thread talking about possible blown fuse, but I'm not so sure how to check it.
I have the stock casette radio with 6 cd changer in glove box. Thanks
Old Jul 30, 2006 | 09:02 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Look in the fusepanel and pull out the fuse. What you are looking for is a crack in the metal strip.
Another thing it could be is that the radio could be considered non-essential and is shut off due to low voltage. If you had in on when shutting off the car you may have to press and turn it on again
