H&R Suspension Problem (HELP)
Old Aug 1, 2006 | 11:51 PM
simoncorona's Avatar
2006 C-200 Kompressor (W-203)
Hi Guys, I install the H&R Springs in my car 1 week ago.
Everything was perfect but today i hear a weird noise in the Passeger Side (Front).
Its sounds like (Knock,Knock) usually at low speed.
What do you think ???
Is this normal ???
How can i fixed ???
Thanks..........
Old Aug 2, 2006 | 01:41 AM
EV0LVE's Avatar
F10
is the car slammed to the ground? it could be the spring loose on the perch, it's not getting compressed enough because it's slammed, if it is. Otherwise go back to the installer, if you did it yourself, jack it up and redo what you did, those are the things I'll be doing if I was in your position. Goodluck
Old Aug 2, 2006 | 02:17 AM
Hot Tomato's Avatar
Black C200 Kompressor
Make sure the springs are seated in the housing properly. We did a friend's ridde recently with H&R and the rear left side wasn't seated in properly when we installed it, had noises too....gotta love DIY
