Winter Wheel Questions
Old Aug 29, 2002 | 08:12 AM
mercedesman's Avatar
I've got some snow tires/wheels left over from my previous car that I'd like to use and would like to know if they'd fit my new c230 coupe? They are from a '99 VW Passat and are 5x112 with 37 back spacing in a size 15"x 6.5 steel wheel. Id like to know if they'll fit and what are the specs for the stock wheels that come on the coupe are? Thanks
Old Aug 29, 2002 | 11:41 AM
Freddy's Avatar
I would say no. Coupe stock wheels are 16". Also the center is different size on MB and VW.
Old Aug 29, 2002 | 12:09 PM
Just found out I have to go with 16", guess I'm getting new wheels. Thanks
Old Aug 29, 2002 | 12:42 PM
patronus's Avatar
2001 C240 / 6-speed
The bolt pattern and offset are correct. There are two open ?'s:
1. Are the wheels hub-centered and what is the hub (hole) diameter?
2. Will 15" wheels clear the brakes?
Old Aug 29, 2002 | 02:55 PM
I was told by the guy at Tirerack that the VW center is 57mm and the Mercedes is 66mm.
