w203 armrest rear booster blower wiring
Here is a photo of my armrest centre console that has the optional booster blower.
There are two wiring connectors in the very front of the armrest centre console that have to be connected so that the rear booster blower is operable.
My car did not have from factory this option.
My question is what optional wiring harness do I need for connecting the rear booster blower? I assume that the one connector is for powering up the motor and the other for controling the rear air vent and communicating with the digital climate control fascia.
thank you
thank you
already checked. there is no booster blower retrofit chapter
since you have done this to your car you must know better what to do to connect it and what extra wiring i need just for the booster blower. it is annoying having the booster blower under the armrest and no way to make it functional at the monent.
W203 slightly modified
if it's not in the retrofit section check the main section so you know where it plugs into. THe plug the booster blower plugs into is part of the 581 harness like benzmodz said which is a feature that was never in your car so ordering the 581 harness would be a good start.
Originally Posted by BadAssC230k
pardon my asking, but what exactly is this for again?
The booster blower is for the rear seat passangers. It is part of the factory climatronic (digital climate) package and pulls in air from along the walls of the center console and pushes it to the rear for the back seat passangers. The speed of the blower is controlled via the dial in the rear.
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
Former Vendor of MBWorld
some slow@$$diesels
I just checked the main section but nothing there, unless I cannot find it somehow.
keyword: WIS
greetingz,
W205 C250BT & R320cdi-L V251 (sold c220 cdi Elegance)
i have this factory fitted in my 03 C220cdi and my blower periodically has a mind of its own. if i have it set on high, it will run high for a while and then out of the blue it drops speed on its own then fluctuates back to its original fan speed (usually high)
Any suggestions for fixing this?
I thought it may have been poor contacts but that would usually mean full speed or no speed.
Anyways, im keen to hear any feedback.
Has anyone completed this retrofit and is willing to share info/pictures of the install and post about the results?
Looking to install and add to my digital climate controller (adding Sun/Solar and Smog/Multifunction Sensors)...
So far I found I have...
203 830 0308 Fan
203 835 0119 Cover #1
203 830 1313 Cover #2
203 680 0468 Liner
203 540 1913 Wire Harness
Thanks,
Jake
203 830 0308 Fan
203 680 0468 Liner
Thanks,
Jake
