CHeck engine light is on
1- P0103 = Air flow signal voltage high
2- P0172 = System two rich bank #1
They think that is the Air flow sensor. But I would to make sure because I call and the price for it is almost 400$ (just the part.) I am going to try to use some electronic cleaner to see if I can fix that sometimes it helps( my friend told ) please let me know I don’t want to throw away 500 $ without fix the problem. Plus my panoramic roof is falling to close. It has a pop op op op noise when it is closing just at the end when it is almost close, I had to close it manually.
Thank you for the help
Do you recommend something else? I am not much of a mechanic but with a little help I know I can do this. I already bought the paper benz air filter.
Please advise me. I need it.
If you really want a new maf or the one you have is beyond cleaning, there's someone selling one on the forum, maybe he'll chime in. If not check out Duval Motors, an MB dealer that discounts, should be $320 or so.
Lastly, vacuum out the air filter box and put in a new filter, you don't want to recontaminate the MAF.
I have a couple of questions... I need to perform service B in my car, but i want also to change the plugs, and gas filter. Is that necessary?? my car has 52k miles. i got a friend that for the plugs charge me only 60 bucks labor, but if you have any recommendation that what should do to my car please let now.
Thank youuuuu again
