Top vents blow cool air, while feet vents blow hot when heat is on?
Anyone have any experience with this?
to the OP, just turn the dial down as far as possible to have to blue showing. That controls the air coming from outside btw.
I have both heat/air dials turned to maximum heat (solid red). Check out www.installuniversity.com/images/controls.jpg and you can see the positions everything is in.
The two vents in the center above the door lock/unlock blow cool air while my feet get hot air. I would expect to get hot air at my feet and no air anywhere else. Is this normal?
My wife drives this car so when I experienced this I was like, $%$^$&$, another problem.
Thanks again!
Eric
www.InstallUniversity.com
I just checked on my car and when it is set completely to blow at the feet there is a small amount of air from the side dash vents, probably to keep some air flow on the side window to keep them from fogging up.
So, I would have to say it is normal.
