Control Arm Questions....
Old Oct 16, 2006 | 05:55 PM
RichW's Avatar
2002 C230 Coupe
I have a 2002 C230 coupe, and I have a rattle coming my front driver's side suspension when I go over a bumpy road (say a gravel road). Jacked the car up, and started tapping around with the rubber mallet to see if I could find the rattle.
When I tapped the control arm which is mounted higher on the wheel hub assembly I hear a rattle, when I goto the same one on the passenger side, no rattle, sounds solid so I think the problem lies here.
My question is this, is the control arm which is mounted higher on the wheel hub assmebly considered the "upper" control arm, and the one mounted lower the "lower" control arm? If not how exactly do you tell the difference between the "upper" and "lower" control arms?
I just want to make sure before I go and order the parts. Should I replace all the bushings (lower and upper) while I'm at it?
Thanks in Advance,
Rich...
Old Oct 17, 2006 | 01:14 AM
Benztecg's Avatar
c230k
Thanks in Advance,
Rich...
Check the largest control arm bushing usualy they crack and they oil charged as well so you should see wet spot.
Old Oct 17, 2006 | 08:48 AM
WaveyKat's Avatar
Something Slow
search this W203 forum "Control Arm" u will see a recent post about this noise
Old Oct 17, 2006 | 04:54 PM
RichW's Avatar
2002 C230 Coupe
Hey I did the search, and I found a few discussions regarding control arms/rods & bushings. However is there any thread specifically you are referring to?
Rich...
