1/6 evo carlsson doesn't fit w203???!
I got 1/6 evo carlsson rims, and i tried to put those on 2004 c240, but they rub the suspension. And the workship guy told me if i use spacer on my car, it will rub the fender.
Anyone can help give me a suggestion?
Thanks a lot.
Thanks a lot.
Thanks for replying me.
ET for front is 40 and 45 for rear. and the rims are 19/8.5 front, 19/10 rear.
i saw him put a front wheel and it was rubbing a little bit without the bolds on.
And I'm planning to lowered my car after this, so I think it will be more rub after that, right? (if somehow the rims can be fitted.)
you always have to run Carlsson's own spacer on their rims.
all their rims come out to be either ET40 or ET45.
you'll need a 12mm spacer for the front and 10mm for the rear. they'll come with bolts if ordered from Carlsson about $50-60 per wheel.
Do i need any other extension to get them fit?
