Secondary Air Injection System
Old Nov 8, 2006 | 10:17 PM
Benzot's Avatar
My "Check Engine" is ON. The last thing I did was put a Fuel System Cleaner in my Fuel tank. Engine sounds so smooth, quiet. Pick-up is better.
The mechanic hooked-up the computer and read
"Secondary Air Injection System malfunctioning"
Any suggestions. My friend and I thought first it was just the Oxygen sensor. might be able to get away with it by cleaning or replacing.
Please HELP!!!
Old Nov 10, 2008 | 08:11 PM
gurpsingh's Avatar
CLK 230komp
I got exactly the same on my 01 CLK 230k. Any1 help... PLEASE!!
Old Nov 11, 2008 | 12:20 AM
tranly98's Avatar
2003 C230 KOMPRESSOR SEDAN
03 c230 kompressor sedan, I have the same cel and I changed the combination valva or call the change over valve and the cel went away. Hope this would help.
Old Nov 11, 2008 | 11:13 PM
herksmerc's Avatar
2005 c230k
the what? change valva.......
Old Nov 12, 2008 | 02:54 AM
lynall's Avatar
E430 Avanrgarde
Dont know what engine you have but my wifes W203 320 sec air pump is right at the front of the vee and the two valveS that control the flow of air into the engine are right behind it.
Lynall
Old Nov 12, 2008 | 02:56 AM
lynall's Avatar
E430 Avanrgarde
See here http://www.detali.ru/cat/oem_mb2.asp...SGR=105&SGN=04 item 5
Lynall
Old Nov 13, 2008 | 12:59 AM
tranly98's Avatar
sorry, i meant the change over valve.
Old Nov 13, 2008 | 01:01 AM
tranly98's Avatar
I have 2003 C230 kompressor 1.8l sedan.
