Need Help Cutting The Front Spring...
Old Nov 10, 2006 | 05:25 PM
bloodyhands's Avatar
2k1 c320, 2k5 wrangler, cbr 929
Ok i have h&r cup kit and i wanna take an inch off the front spring...how many coil should i take off?The reason i wanna cut the front is because the back is so much lower then the front that i had to put 2 spring pad in the rear to level out the car.i like the drop of the rear with 1 pad but then the front would be higher.Right now its leveled at 1 and a half finger gap,i want no gap.
Old Nov 10, 2006 | 07:28 PM
ClayJ's Avatar
ON PROBATION
DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS. DON'T CUT THE SPRINGS.
Old Nov 10, 2006 | 07:44 PM
is it ok to have 2 spring pads in the rear
Old Nov 10, 2006 | 07:50 PM
anthuny85's Avatar
06 c230 v6 SS
put a #1 pad in the rear, cut the front 1 coil, id say, i have a half cut coil in the front, my drop sits really nice. but i think the cup kit isnt as low as the sport springs.
Old Nov 10, 2006 | 08:37 PM
white_w203's Avatar
is SOLD
one coil should be good enough. h&r has a pretty stiff spring rate so it should be fine.
Old Nov 11, 2006 | 03:11 AM
alright thnx guys
Old Nov 12, 2006 | 03:22 AM
C240Style's Avatar
Mercedes is gone physically, but still in my heart.
Cutting the coil probably isn't the best thing to do. You'll have a hell of a time trying to get that car properly aligned again.
Old Nov 12, 2006 | 10:36 AM
mbbodytech's Avatar
04 C320 Coupe MT
I second that!
Old Nov 12, 2006 | 10:57 AM
dnasty8305's Avatar
2003 c240
chop chop you will be good trust me a half to one coil you will be fine now chop chop ..................
Old Nov 12, 2006 | 11:04 AM
Brunelleschi's Avatar
In the market
general rule of thumb....1" drop per 1/2 coil cut, but that is only somewhat true for about the first 1 and a half coils. It's not linear or a science. Would definitely not reccomend doing it but to each his own
Old Nov 12, 2006 | 01:36 PM
SUNILP's Avatar
2015 E250D
Originally Posted by mbbodytech
I second that!
I third that!
Old Nov 12, 2006 | 09:44 PM
What The!?'s Avatar
It's a bad idea. Don;t ever cut your springs. Unless you like that bouncy feeling
Old Nov 12, 2006 | 10:36 PM
In the market
Since you put it that way..maybe cutting the springs isn't such a bad idea
Old Nov 12, 2006 | 11:44 PM
anthuny85's Avatar
06 c230 v6 SS
1/2-1 coil cut on a german car is completely diff. compared to a honda/acura. especially on a aftermarket spring that has a stiffer spring rate, u will barely notice it.
Old Nov 13, 2006 | 01:24 AM
ok so cut 1/2 of a coil cuz 1 coil would be 2inches lower right?
Old Nov 13, 2006 | 03:16 AM
CynCarvin32's Avatar
Mercedes Benz
Originally Posted by sunman
I third that!
+3
who the heck cuts a spring?
Old Nov 13, 2006 | 10:20 AM
What The!?'s Avatar
It's actually not that different. A spring is a spring.
They were designed with a certain spring rate. Lopping off "dead coils" on any spring completely compensates the original design of the spring and makes it unpredictable. You'll ruin it if you cut it.
To the OP: Do it the right way, get a spring or coilover that will let you sit at the height you want. It'll cost you more in the long run as you'll find other issues that pop up over time. But hey...to each his own.
Old Nov 13, 2006 | 12:03 PM
viprsx's Avatar
WALD W203
pansy.. I have had cut spring on my 330I for 2 years and nothing happend..
Just don't cut more than 2 coils, should be fine.
Old Nov 13, 2006 | 01:07 PM
anthuny85's Avatar
06 c230 v6 SS
hahaha....listen to the ppl that have had this done...especially with h&r springs..if u have questions or doubts, pm darwin at carlab, he'll give you the lowdown. were not telling u to cut ur springs in half.
Old Nov 13, 2006 | 01:59 PM
CarLAB's Avatar
1/2 to 1 coil max. Over 1 coil is considered unsafe unless you use a shorter shocks like koni yellow. Make sure the guy doing it knows how to seat the spring properly otherwise it'll be making noises.
If you want to use pad #1 in the rear cut 1/2 coil in the front should help level it out. 1 coil is to agressive and can messed up your fender if its not rolled.
Regards
Darwin W
Old Nov 13, 2006 | 04:38 PM
ok 1/2 coil it is thnx guys i'll post some pix soon
Old Nov 13, 2006 | 05:09 PM
gcwaterski's Avatar
01 C320, 07 Tacoma, 67 F100, 08 boxter S
Okay, sorry to Hijack your thread- But hows the H&R CupKit? I am planning on ordering it this week sometime with some wheels, and was wondering if youall suggest it having already got it.
Its for a 01 C320, I am putting 18s or 19s and want to close that goofy fender gap in the front. I dont want the back to be tucked too bad, but definetly want the front sitting low-
Go with CupKit? OR something else??
Old Nov 13, 2006 | 06:19 PM
CarLAB's Avatar
For the price of a H&R cupkit, you might as well add some more money and get a TEIN basic coilover. The coilover will take care of the unwanted front wheel gap you mention.
call us we can get you set up with the right wheels and suspensions system.
Regards
Darwin W
Old Nov 13, 2006 | 06:59 PM
In the market
oh hell....how many coils are there on the spring....remind me....5....i'd say....cut two and half and you should be good
