Pictorial Request: How/what to dremal and/or remove from wheel wells to stop rubbing
Old Nov 17, 2006 | 12:56 PM
SFoRZA's Avatar
C32 AMG 2002
Question Pictorial Request: How/what to dremal and/or remove from wheel wells to stop rubbing
I think this is a topic that many threads have touched on, however none give a conclusive answer or "how to."
The author would probably be revered as somewhat of a supernatural being.... at least in my book.
Old Nov 17, 2006 | 05:25 PM
white_w203's Avatar
is SOLD
umm i would dremal anything on the fender. could cause rust. rolling the fender is the most i would do. otherwise, just get the correct offset of the wheels.
Old Nov 17, 2006 | 11:29 PM
rlee02135's Avatar
2004 C32 ///AMG
i heard you have to dremel a part where the fender meets the bumper
Old Nov 18, 2006 | 01:14 AM
gaogi's Avatar
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
It's around the upper edge of the moulding on the bumper. Stick your finger under there and feel around in the general area, and you'll feel something sticking out. Or, if you have already put your wheels on, and you have rubbed, just look for the part that is worn from the rubbing. The paint on that part would be rubbed off a little.
Old Nov 20, 2006 | 03:03 PM
SFoRZA's Avatar
C32 AMG 2002
Ok this is defiantly the piece rubbing (the one circled) I grinded it down with a dremal and have a lot less rubbing around hard turns....
Question: The piece that’s circled has a hollow part.. kind of makes a [] with the inside empty.. do you think if I grinded away the whole outer side i would have a problem? i think the piece helps hold the panels of the car together, however it looks like i should be ok.... ..... help.
Old Nov 20, 2006 | 05:22 PM
rlee02135's Avatar
2004 C32 ///AMG
i know that is the rear wheel but is the pic facing the front or back?
Old Nov 20, 2006 | 10:17 PM
SFoRZA's Avatar
C32 AMG 2002
oh, the pic is taken from my back on the ground, so i guess rotate it 90degrees counter clock wise
Old Nov 22, 2006 | 02:30 PM
SFoRZA's Avatar
C32 AMG 2002
sooo we think the bumper will fall off if i grind it down right?.....
Old Feb 22, 2007 | 07:32 AM
SFoRZA's Avatar
C32 AMG 2002
bumpers still on, all is good..
Old Feb 22, 2007 | 11:10 AM
rlee02135's Avatar
2004 C32 ///AMG
still rubbing?
Old Jan 3, 2009 | 09:13 AM
SFoRZA's Avatar
C32 AMG 2002
not nearly as much, only when i have a lot of weight in the car... (sorry to reply a year later)
