HELP: Braking Issues
Old Nov 19, 2006 | 03:29 PM
tee_tz's Avatar
ML63 AMG
So I changed my wheels yesterday to some Mercedes sports wheels (17") and after I started driving I started hearing the brakes 'grind' while braking. When I had my old 16" wheels I didn't hear the sound, so I'm curious did anyone experience this or have any idea what's going on?
Also, do you guy know where I can get an AMG Brake Kit? Or at least have the part number for the 2007 C-Class brakes (with the 'Mercedes Benz' wording on the brake)?
Thanks.
Tee_Tz.
Old Nov 19, 2006 | 04:36 PM
sirenebekim's Avatar
when i installed my rims i had to shave my lugs, try that and the noise should go away.
Old Nov 19, 2006 | 05:10 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Definitely check the lugs. If the wheel thickness if less, you can do some real damage to the rear brakes (if the wheel bolts are too long).
Old Nov 19, 2006 | 05:59 PM
rlee02135's Avatar
2004 C32 ///AMG
Evosport sells the C32/C55 AMG brake kit.
Also, the 2005-2007 brakes are the same
Old Nov 19, 2006 | 06:57 PM
coin's Avatar
'06 CLK500
Don't ride the car with the noise .. I used to have those clicking noise too but after changing the lugs to the correct length, the sounds ..
Old Nov 19, 2006 | 09:15 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
yah
you have to make sure the bolts are the correct ones for that wheel
Old Nov 20, 2006 | 01:36 AM
white_w203's Avatar
is SOLD
if you put on the factory 17 inch wheels switching over from the 16 inch factory wheels the lugnuts should be the same. the bolts should be the right size.
Old Nov 20, 2006 | 10:32 AM
tee_tz's Avatar
ML63 AMG
white_w203 - Yeah, exactly, I took off the factory 16" wheels to put factory 17" wheels (both Mercedes OEM), therefore, I'm surprised I would need to do anything to the car-?
And I used the bolts from my 16" wheels for the 17" wheels, Mercedes said they bolts are the same, or did the guy lie to me?
Tee_Tz.
Old Nov 20, 2006 | 08:39 PM
tee_tz's Avatar
ML63 AMG
Guys - so should I still shave the lugs?
Tee_Tz.
Old Nov 20, 2006 | 08:46 PM
rlee02135's Avatar
2004 C32 ///AMG
mercedes sport wheels are staggered, so the bolt sizes are different.
post the width ans offset of all 8 wheels (its on the back of the rim...16x_ et_)
Old Nov 21, 2006 | 12:28 AM
gaogi's Avatar
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
Actually, even though they are staggered, all the bolts are still the same length. I had all 20 bolts off once, and they were all the same.
