Anyone have access to service manual?
I need to see more detailed service specifications such as torque settings, brake bleed sequence, type/vol fluid, etc... If someone can copy paste images into forum or email me, I am very thankful for that.
I will be doing the following:
Full coolant flush
Auto tranny drain/fill
Diff fluid drain/fill
Bleed brakes
New Fuel filter
New Air filter
I realize that these cars come with "lifetime" this and that. But I want to keep this car for a long time. I have seen what happens to 90s BMW auto trannies that never had their "lifetime" fluid changed. I also apologize for grammar mistakes as English is not my first language.
I have to agree with you that extended change intervals seem too good to be true, but the engineering for the motor oils work. The correct 0w-40 Mobil 1 oil that meets the Mercedes spec sheet, with the fleece oil filter realy does allow 1 year or 13,000 mile oil change interval, without causing excessive engine wear.
I am not sure how these motors tolerate lack of antifreeze changes. Some need head gasket replacement if it wasn't changed rigilously every 2 years. It's just a good thing to do, can't hurt.
You are probably right about the engine oil. I will eventually get an oil analysis done to see if that 13k interval is OK. But above all, if you do all the maintance yourself, the cost of doing preemptive maintance is cheap. Also realize that according to MB 1qt per 1000mi is considered OK. In my book, for non-performance engine it is not. Wouldn't you rather not have that by just doing a few extra oil changes?
