Old Jun 10, 2015, 03:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How to change battery of the Remote
Old Nov 28, 2006 | 02:37 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
Hi,
I want to know how to chang ethe battery of the remote
cause my remotes seems to be low on battery
and there is no screws that i can see to, how do I open the remote??
if it's possilbe.
or, is this key like the bimmers, which gets charged when driving???
Old Nov 28, 2006 | 02:41 AM
14cue's Avatar
05 C55
did your car not come with a manual?
simply take out the smart-key then use it to push in the little clip that holds it in, then as you push it all the way you can pull it out- it's hard to describe, but it's super easy, just play with it, you wont break it and there are no screws.
Old Nov 28, 2006 | 02:46 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
i did the search and found this
https://mbworld.org/forums/showthrea...remote+battery
when i push it in, it doesn't pull it out
do i have to push very hard, cause I don't want to break it
Old Nov 28, 2006 | 02:55 AM
14cue's Avatar
05 C55
push hard enough till you cant push anymore then you should be able to stick your finger nails in btw the crack and pull. you wont break it. the button is directly to the side of the button to release the smark key. its probably dusty and hasnt been opened in awhile is all.
Old Nov 28, 2006 | 04:12 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
thanks
i got it opened
