report: 2 weeks with ASP pulley
Ok folks, first I must apologize to all waiting for my feedback since I promised it about 2 weeks ago.
I needed this time to assess all aspects of the pulley upgrade results and to let my excitement subside a little - otherwise it would have been rather biased
First, impressions. The car now simply can't be driven slowly. It revs so happily, I have a silly grin on my face almost all the time - when there is open space, that is. It has turned the 6th gear from a cruising gear into a pulling one - my seat-o-the-pants accelerometer makes me doubt and visually check if it is in 6th gear indeed.
An S4 tried to pull from me at 40mph the other day- and couldn't!!! I had no doubt he would eventually have pulled away at higher speeds, but I stayed with him very authoritatively all the way up to 70mph, when we both had to slow down as we ran out of road. That was a big WOW! Never thought the coupe could touch this league. OTOH, maybe he wasn't too good a driver, but still - he was trying...
Now, the car feels a little rougher (my settings are "Base" ignition and "Stage 2" fuel), and I seem to feel this even through the shifter knob. No fault codes have been thrown, though. Not sure what this means, maybe I should try different fuel/ignition settings and compare? Or maybe it's the tires - they tend to roughen the ride as they wear off.
The added power made it evident that the car needs a stiffer suspension. In its stock form it squats, dives and leans too much. So - sway bars on the way, springs haven't been chosen yet.
Supercharger growl is more pronounced now at all speeds, including idle. I like it. It somewhat masks that characteristic B&S noise.
Now, installation. It wasn't as easy as I had expected.
First, removed the stock pulley, no problem... Aligned the key so it was at the top; lubed the ASP pulley, tried to slide it on - no go!
I could only push it as far as the lead-in section allowed... Then the lip that you can feel with a nail would prevent it from getting any further... (By contrast, the stock pulley would side on and off without any problem, still fitted tightly when in position).
At first I thought that the key groove wasn't deep enough, and tried to enlarge its entrance with a small file - still no go... In process, to my horror, I found that the pulley got slightly reamed near the groove... Anyway, after I realized that it wasn't the groove that was preventing the pulley from getting on, I used fine sandpaper to smoothen the lip, and did a few iterations of that between attempts to slide it on... Finally it felt like the pulley moved past the lip point, the groove found the key, and although I couldn't slide the pulley any further by hand (despite heavy lubrication with graphite lube), I used the bolt to slide it in position. It worked - the pulley looked true, no wobbling.
Whoever decides to install an aftermarket crankshaft pulley - good luck! You'll love the result, but be careful with installation. I used a nice step-by-step manual created by Buellwinkle, for which I'd like to thank him.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
C230 Coupe
Sounds good, where you said "my settings are "Base" ignition and "Stage 2" fuel," Where do you get these changed? At the dealhership? Do they need to be changed? Also would a dealership install the pulley? And last how much does the ASP pulley cost? Sorry for all the question but im very interested in buying since you seem very happy with yours.
Yes, the fuel parameter should be set to Stage 2 or Stage 3, most converge in their opinion on Stage 2 as the optimal one. As for whether a dealership will install the pulley - it depends. There are diametrically opposite reports on this issue by forum members. The ASP pulley can be purchased directly from ASP, for $350 + s/h.
1 Post
99' SLK 230 & 01' CLK 430
Now, installation. It wasn't as easy as I had expected. First, removed the stock pulley, no problem... Aligned the key so it was at the top; lubed the ASP pulley, tried to slide it on - no go! I could only push it as far as the lead-in section allowed... Then the lip that you can feel with a nail would prevent it from getting any further... (By contrast, the stock pulley would side on and off without any problem, still fitted tightly when in position).
Originally posted by linh
I didn't have any problem installed kleemann pulley on my Slk and ASP pulley on Buellwinkle. I'm surprised that you have little problem. Btw, the pulley is a press-fit type, so there's no way you can push it all the way in with your hand. The only way to push it all the way in is by tighting the screw.
Could it have been the heat of the crankshaft? It was expanded and the new pulley was cold? Just a thought. My factory pulley was a pain to get off and back on as I've done this twice. I didn't notice much difference between installing the factory pulley vs. the new pulley.
Originally posted by who_dog
Are you at all worried that you had to file and sand your new pulley? Couldn't that disturb the balance of it at high RPM's and hurt the SC?
Also, it wouldn't hurt the SC since it is not a SC pulley, but a crankshaft one.
So, if it's that tight.....
how woould you remove it, as so many people discuss, as in
putting it back stock to maintain the warranty?
If it's on that tight, doesn't sound like it's gonna come off....
guess you'd need a special tool?
What was the total time for install?
Vadim,
also what were the settings set to before you had them changed?
Stage ? etc.
Stage ? etc.
Re: So, if it's that tight.....
But if this is a concern don't worry about it. Each pulley is made to order, just specify how lose you want it, it's your car, have it your way (like Burger King).
Vadim,
Stage ? etc.
Vadim,
Stage ? etc.
As for the ignition parameter, I had tried RON 93, and then reverted back to Base, where it is now. Again, these changes had been performed before the pulley was installed.
This is a tricky issue, as there is no 100% credible information about the meaning of the numbers each setting is designated by. Some say it's "RON 93" (translates into US 97-98 pump octane rating), others argue that it *is* the US octane number, and "RON" was used in the software by mistake. Moreover, some claim that "Base" actually means "RON 95" and is therefore the best setting to pick. Others counter that Base is for average gasoline, whereas "93" allows for most ignition advance and is therefore the best.
But - all of the above is based on guessing and *some* knowledge of the subject. Not enough facts, though. So, here we are - left to wait until someone steps up and conducts exhaustive tests that would put an end to this eternal argument.
Originally posted by avlis
Isn't that why they make gear pullers? Or is there not enough room to use one under there?
'02 C230K Coupe
Originally posted by vadim
So we are left to wait until someone steps up and conducts exhaustive tests that would put an end to this eternal argument.
I guided the pulley in place and used the gear pusher (aka. the pulley bolt) to ease it in place. It didn't take much effort for it to slide in place, didn't bind or anything.
I strongly agree with vadim's statements about acceleration in sixth gear and the need for the car to be driven fast. I haven't had any opportunities for on road testing with other vehicles.
I also have my settings at Stage II and base ignition. I have noticed a rougher idle at startup at reported by vadim and edvpt. I have not noticed any vibration in the gear shifter.
My recommendations: GET A PULLEY, it will be like driving a new car.
Originally posted by 20FHK02
Wouldn't it be the easiest to get the answer directly from MB? The engineer/programmer/designer who implemented all these ignition and ECU settings must know what they mean.
1 Post
2002 C230 Coupe
That's not going to happen... Of course it would be awfully nice, but this is proprietary information that only MB insiders would be aware of and certaily not willing to share... Well, unless you kidnap them and then torture in the basement of an MB production plant (Hollywood style, imagine: huge tanks and pipes all over, steam bursting out here and there, etc.)
Off to the dyno!
1 Post
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Sounds like a good upgrade...albeit not an easy one. Good luck with it, and put that puppy on a dyno so we can see real wolrd numbers and specs.
How much more Toque gained ???
I see a suggestion of about 35HP increase with the pulley installed. There is no mentioning of any increase in accompanying torque that I know of? Honda & Acura tune their engines to produce more HP yet can barely add any significant torque.
Are we seeing the samething here?
Pls educate me.
Peace
Pls educate me.
Peace
Adding Pulley at MB dealer ???
Some think that this can be done at the dealer. I called my local MB service department about having them install the pulley for me.
They are not even returning my calls (2)![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Peace
Peace
Re: How much more Toque gained ???
Pls educate me.
Peace
Pls educate me.
Peace
(Torque x RPM)/5252 = HP
Therefore, if HP is increased, Torque numbers at those RPM's is increased as well
