Noise At 115+mph HELP!
Old Dec 18, 2006 | 07:41 AM
moose1021's Avatar
2007 C280 4matic
2007 C280 4matic
My normal driving is about 100mph beside wind noise it is quiet and smooth.
Today i bumped it up to 120mph not much more wind noise and still smooth but there was a hollow popping sound from i'm guessing the tranmisson area.
It was under the Arm rest.
Should i just not go that fast or could there be a problem?
Can our cars handle that speed?
Old Dec 18, 2006 | 09:43 AM
BKLYN_C's Avatar
MB
The C class was engineered to go way faster that 120. The ECU will limit you at 135, but that's a US DOT reglamentation.
I would talk to dealer about these noises. At this speed sounds may be very misleading and the real sourse of it may be some where else, not under your armrest.
Old Dec 18, 2006 | 09:57 AM
MHPHOCKEY's Avatar
2014 Audi S5 Cabriolet 3.0T
The car can go that fast...maybe you should check it out. You should also realize that you die if something does go wrong...
Old Dec 18, 2006 | 10:31 AM
bloodyhands's Avatar
2k1 c320, 2k5 wrangler, cbr 929
ummmmmmm you should break in the motor and tranny first
and your normal driving should be 65mph considering you have a child. i wouldnt give a f**k if you said your normal driving is 65 and once in a blue you go 130+.
Old Dec 18, 2006 | 10:36 AM
MHPHOCKEY's Avatar
most new cars dont need break in. I have a friend who just bought a 550i (BMW) and I got a SL 550 and the dealer specifically said no break in necessary!
Old Dec 18, 2006 | 10:43 AM
BKLYN_C's Avatar
MB
With leased cars who cares about break in or maintanace? But if you plan to keep it then no matter what dealer says you still want to break it in
Old Dec 18, 2006 | 10:59 AM
mctwin2kman's Avatar
Did you not note that his location is Germany! Not all Countries have low *** speed limits.
To the OP, sounds like and air pocket buffeting under the vehicle in the transmission tunnel. Take a look under there and make sure you do not have a bag or string or other debris under there. Also these cars are designed to handle up to there limit speed wise. Which for yours is probably around 150MPH. But I would bend down and take a peak under her and if you can not find anything then talk to the dealer. I know mine handle just fine at the 132 MPH limit set for the US. No strange noises either. But at that speed you may be hearing a panel that is loose or just wind. I have not driven a 2007 yet so maybe they do not have as much sound insulation as the previous models due to MB cutting costs to make more money per unit.
Old Dec 18, 2006 | 11:48 AM
3onDubs's Avatar
GLK 350
I just bought an 07 C230 and the dealer said that, although they recommend driving on "comfort mode" for the first 1000 miles or so, it isn't really required.
Old Dec 18, 2006 | 12:07 PM
moose1021's Avatar
2007 C280 4matic
As for break in period it has 6000 miles on it.
If i was going 65mph i would get ran over on the autobahn and i only break 100 when the kids not in the car. 100mph is slow for here. i'm gonna hate coming back to the states for that reason.
Well the loose panel could be it. The car was just in the dealer and they replaced the fuel pump because a valve on it was rattling. I will call them tomorrow because i dont remember the nosie before but i don't really break 100mph that often either.
thanks for the reponse
Old Dec 18, 2006 | 12:18 PM
sirenebekim's Avatar
ive had mine to 146 and it was quiet/stable as a church pugh.
Old Dec 18, 2006 | 02:42 PM
hss0p's Avatar
It will be interesting to see what your dealer does about this. I took my bmw 2006 x5 4.8 into the dealer because it made a whistle noise around 90 from the sunroof. They said that they cannot find out where the leak is coming from, because the bmw dealership wont let them go above 75. BS if you ask me.
Old Dec 18, 2006 | 02:49 PM
slammedcclass's Avatar
cclass05
this is funny cuz 100mph is nothing if u go 80 or 100 u will die any way so why not just go 120 130. I wish i lived in Germany cuz i dont want to spend any more money for speeding tickets
Old Dec 18, 2006 | 03:59 PM
Elliott's Avatar
'03 C230 Sedan
profound.
Old Dec 18, 2006 | 04:53 PM
cclass05
u drive and they in da seat next to u haha those ****** in bmw will be scared to go 90 lol i test drove mercedes and took it to 100mph and it had only 13 miles on it haha i asked the guy if he was scrared and he said nah these cars are safe
Old Dec 18, 2006 | 05:25 PM
BKLYN_C's Avatar
MB
There is no car in existence that will guarranty your survival in 100 mph collision. Don't believe? - look at wreckedexotics.com
Old Dec 19, 2006 | 03:07 AM
Moviela's Avatar
"Break in" refers to physically breaking the peaks off the crosshatching on the cylinder walls in the engine with special oil to capture the debris. This is old school. Break in oils are not put in Mercedes cars because the factory uses a planar honing process that results in a cylinder surface finish that is better than an old school engine that had been properly "broken in."
The are a lot of things your father did with his car that are no longer required.
Examples:
1. Break in
2. Pump the gas pedal to start the car.
3. Warm up the car before driving.
4. Motor oil is motor oil, its all the same, buy the cheapest.
5. Only use pure antifreeze to top off the radiator.
6. Brake fluid lasts forever.
7. Premium gas is a waste of money, the carmakers are in bed with the oil companies.
Old Dec 19, 2006 | 04:59 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
+1
Old Dec 19, 2006 | 05:01 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
safe enough to be dead..
Old Dec 19, 2006 | 09:39 AM
BKLYN_C's Avatar
MB
Examples:
1. Break in
About break in you are right in the matter of shaving the peaks off the cylinders, but besides cylinders, pistons and rings engines have sh*t load of other components which all are made with manufacturing tolerances. Yes, all the components are interchangeable, but this is not a Kalashnikov where you don't care and just shoot. Even with AK which were designed to work no matter what we experienced lots of variations and issues.
Now I will tell you something about Warm up the car before driving. With rising temperature material expands and this means that your engine was designed to work at higher temperatures. Cylinders are steel and pistons aluminum. Their linear expansion differs and this difference makes your car feel little "stronger" when it's cold causing more friction, tension and faster wear. The result is your engine will not last as long as it was intended.
Pump the gas pedal to start the car. Nowadays the ECU does it for you, but if you do press the accelerator it will not hurt your car.
Brake fluid lasts forever. It may last you forever. Now don’t get me wrong, I don’t say not to change it as recommended by your service manual, that’s different story. The brake fluid doesn’t evaporate from the enclosed system. If you see the level lowered, you should check for leaks
Old Dec 19, 2006 | 02:12 PM
moose1021's Avatar
2007 C280 4matic
Well took the car to the dealer and they are saying it wind noise that i should not be having. After the new year i'm taking the car back and they are going to try and find whats causing it.
Thanks for your replies.
Old Dec 19, 2006 | 04:25 PM
StillKickin's Avatar
Mine 2005 C230 Kompressor, Dad's 2005 ML350
Im jealous I want to drive my car at 100 without trouble, it feels so at home and stable at 100+
Old Dec 19, 2006 | 04:40 PM
BKLYN_C's Avatar
MB
Man, tonight Belt Pk-way is all yours
Old Dec 19, 2006 | 04:45 PM
I wish, I drive the belt from JFK home twice a day everyday, the amount of accidents I see I never go over 70 on it, that and cops arent very friendly, my buddy showed them a military ID and they said that since hes military he should know better instead of giving him the courtesy, its effin retarded.
Old Dec 19, 2006 | 11:36 PM
BKLYN_C's Avatar
MB
Tell you friend to get a detector
Seriously, I am not a saint and love high speed, especially just after the JFK exit where most normal people get off for the airport, go into the right lane and enjoy, no cops there ever. But on the other note, cops are not idiots eather, so I never go over speed limit + 25, just to keep my license in case sh$t happens
Old Dec 20, 2006 | 03:57 AM
moose1021's Avatar
2007 C280 4matic
Trust me it nothing special. When i first got here I was really excited to go fast but now it normal everyday autobahn driving.
