Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tire Repair and Maintenance
- Mercedes-Benz C-Class: How to Change a Tire
Step by step instructions for do-it-yourself repairs
how to remove rear tire, it's not coming off.
'04 c230 SS, '06 RR supercharge sport, '06 z4 M Roadster
So, I took the bolts off of my flat tire and I can't seem to get the tire off.
I've changed my civic's flat tire and it was pretty simple.
Am I doing something wrong? Help....
No, you seriously have to kick it off.
I had a loaner not to long ago and I thought they had glued the rims onto the hub. Called the dealer and my service advisor to literally kick off the rim.
Even with that dinky spare jack that they have? What if I kick it and the car falls off of that jack....
=( That jack is pathetic...me so scared!
It was about 5:30PM and getting dark fast while I was near college. That means I was not at UH, but near 3rd Ward. Not a place you want to be in, especially in a Mercedes.
I told you.
Did you get a flat tire or something?
Make sure you order from Tirerack through our affiliate link![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
http://www.tirerack.com/affiliates/mbworld/index.html
Yeah, you know how I moved into my new townhome? They're still putting up the later phases of the townhomes and so I suspect that I must have gotten a nail from there somewhere....
The tread is somewhat worn, but still okay so I would have had to get new tires soon anyways.
But damn, you really have to kick it.
C55 ///AMG, 535xi
theres two ways this can be resolved.
1. KICK IT! like said above
2. take off all lugs/bolts, drive your car around and the wheel will fly right off. (altho I do not recommend
'05 C55 AMG
when i got a flat and called roadside assistance, they said it was a common issue and advised me to use the spare to hit the wheel that was stuck. worked like a charm.
2005 C230K Sport Sedan, 6 speed manual
I prefer to use a bit less dramatic method:
1. Remove all wheel bolts.
2. Put 2 bolts back in (opposite positions), but leave very loose.
3. Grab the tire at the 3 o'clock and 9 o'clock positions.
4. Aggressively "rock" the tire back and forth until the hub loosens.
5. The 2 bolts holding the wheel on will keep you from falling on your a** when the wheel lets go.
"Wheel sticking" is a common problem on many car brands.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Stage 2 C7 A6, QX60
2002 C230 coupe , NOt THE AVATAR!!
when i brought my coupe to carlab and put on new rims, they showed me that the brake is rust like hell... they have to use arm & hammer power to hit my old wheels off..
but they did everything fast
Here is a simple way to get the wheel off.
Once the bolts are off the wheel, lower the jack until the tire comes into contact with the ground. Then continue slowly lowering until the wheel pops off slightly, then raise the jack again and take the wheel off.
Worked for me everytime the wheel is stuck.
Not too crazy about kciking the wheel, I'm afraid I would knock the car off the jack!
C55 ///AMG, 535xi
Not too crazy about kciking the wheel, I'm afraid I would knock the car off the jack!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I remember removing the lugs on c230 05's brabus reps. dam man, the wheels were stuck. we kicked it a few times. but c230 05 would kick it softly b/c he was afraid that his car would fall off the jack! but i kicked the hell out of them lol
