WD-40 on Stock Wheels?
Old Dec 25, 2006 | 12:46 PM
TA-9FF's Avatar
One with 4 wheels
Hey guys,
I STFF and found one topic regarding spraying WD-40 on a cloth, then spot-wiping the car down to remove grease/tar stains on the paint. I recently had new tires installed on my C, and the stealership mucked on grease stains all over my stock wheels during the installation. I came across the WD-40 thread, but none of the replies there stated if it actually worked or not.........
Is spraying WD-40 on a cloth and wiping the grease off my wheels going to work without damaging the clearcoat/paint on the wheels, or is there a better solution?
Thanks!
Old Dec 25, 2006 | 12:53 PM
rlee02135's Avatar
2004 C32 ///AMG
soap and water
Old Dec 25, 2006 | 02:19 PM
TA-9FF's Avatar
One with 4 wheels
Originally Posted by rlee02135
soap and water
Tried that already; it didn't work.
Old Dec 25, 2006 | 03:40 PM
TA-9FF's Avatar
One with 4 wheels
Anyone?
Old Dec 25, 2006 | 03:43 PM
Pashap5's Avatar
'05 White W203
tar/bug remover ..I think turtlewax makes it
Old Dec 25, 2006 | 03:48 PM
amari's Avatar
Check out any Meguiar's wheel cleaner... awesome products
Old Dec 25, 2006 | 05:12 PM
Moviela's Avatar
WD-40 is a good product, and is a mild solvent. It is good for removing stickers, displacing water from connectors, and chasing squeaks from patio doors, but it leaves a residue.
For cleaning tar, grease and oils from my car I get this stuff from an automotive paint supply shop. (Bob Downey & Sons West Whittier Paint Co.)
It comes in a liter can and is called Sure Solv. Mostly Naptha and Xyelne, a great no residue solvent. Sinks a bit, but does not linger if you remove a grease spot from the carpet.
http://dominionsureseal.com/products...id=15&catid=25
Old Dec 25, 2006 | 06:29 PM
white_w203's Avatar
is SOLD
i use bug and tar remover myself.....it really works
Old Dec 25, 2006 | 09:42 PM
advans's Avatar
C55 ///AMG, 535xi
the black magic spray on cleaner. let it sit, then use that 1850psi spray that I have, and BAM! done.
Old Dec 25, 2006 | 11:34 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
i think personally black magic makes the best tire/wheel products.... i usually go thru the black magic tire shine quick too mmmmmmm i love that shiny look on those tires
Old Dec 27, 2006 | 01:03 PM
Buellwinkle's Avatar
I used WD40, works well for removing stuck on tar, grease, stickers, etc. Safer on paint than using an extreme product like Goof Off that etches into the paint and makes it dull. Just use the WD40 to get the stain off and then wash it with regular car wash soap to clean off the WD40 residue.
Old Dec 27, 2006 | 09:08 PM
Arn560's Avatar
Black 04 C230 Kompressor SS
You make it sound so easy - es[ecially using that spray that you have!
The wheels should be treated as ny painted body part. I scrub with brush, wash with mitt then dry with chamois & paper towel - all using Meguiars Gold class.
Old Dec 28, 2006 | 07:15 AM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Just use SimpleGreen....it's a mild, organic soap/solvent that won't damage the finish....then wax the wheel's with Meguire's or a similar quality product.
Old Dec 28, 2006 | 02:05 PM
TA-9FF's Avatar
One with 4 wheels
Does it leave a residue?
Old Dec 28, 2006 | 02:54 PM
Rick's Avatar
nope....none....zero....zilch
