Engine Wiring Harness
Old Dec 29, 2006 | 06:27 PM
Elliott's Avatar
'03 C230 Sedan
I took my car into the stealership yesterday for the infamous check engine light. They called me today and said some type of oil has leaked all into my engine wiring harness and surrounding components...like a lot of oil. They suspect that it is from the cam shaft timer or something of the sort and I was just curious if anyone has had a similar problem or knows what might be going on. This actually happened a few months ago...repaired by mercedes...and the problem is back again. Annoying.
Old Feb 5, 2007 | 10:01 PM
shermangroup's Avatar
Same thing happened to me, went thru two o2 sensors and then they detected that problem with the harness, wanted 2500 to fix. It is a service bulletin problem from the factory, fix needs to be done or oil will leak into harness and cause o2 sensor to short out. i have not done the fix yet.
