SRS Failure
Old Sep 15, 2002 | 03:35 PM
jj uk's Avatar
c240
SRS Failure
C270cdi june 2002
Just got SRS failure warning message ..switched off ignition a few times message is still there should I return to dealer or wait a couple of days in case it is the computer having a bad day?
a few weeks ago i had warning message that ESP had failed but it cleared within an hour
Old Sep 15, 2002 | 03:36 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Go to the dealer and mention both. They will see them in the computyer, anyway, as error codes are stored in your car's computer memory.
Old Sep 15, 2002 | 04:10 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
could be the fuse or the sensor.
Old Sep 15, 2002 | 11:53 PM
changv's Avatar
2001 C320
I had the same error in my car about 3 months ago. The dealer initially thought it was the driver's air bag. But, it didn't solve the problem. They then determined it was some sort of electrical contact problem. This must have been right as the error message never came back.
Old Sep 16, 2002 | 01:31 AM
peet's Avatar
09 C63
When I was installing my Audio 10 and had the center panel trim out -- it disconnects (from the AC/Heater controls and emergency blinker, plus seat heaters, towing control, door locks).. anyhow, when I started up the engine to make sure all was working in radio - trim still out - I got a SRS failure light. I don't know what's located in that center trim piece but when I plugged it back in it was all fine.
Hopefully this helps someone that may have been tinkering in there! Reseat the plugs.
P
Old Sep 16, 2002 | 04:00 PM
jj uk's Avatar
c240
SRS Failure
Been out in the car all day the SRS message failure came off and on all morning this afternoon back to normal ! work that out should i wait another day before booking the car in for repair?
PS. Peet the car has never been touched since taking delivery only thing i can think of is i had to have a tracker fitted may be behind centre panel?
Old Sep 16, 2002 | 04:16 PM
peet's Avatar
09 C63
Tracker fitted? You mean lojack type thingy?
You may want to pop off the center panel - pretty easy, but you'll need a 20 torx screwdriver. Look for the Audio 10 install thread for step by step.
Then look at the top button section from the rear (it is all one panel).
It has multiple ports, but only some are used. For instance I have heated seats so the driver side has a heavy gauge plug plus the passenger side has a wimpy smaller wire connector. There are other ports - but not all get used.
Any how, one of the port types has two holes -- but only one of them needs to be used ( I don't know which). You may want to check that. Try switching to the other port.
P
Old Sep 16, 2002 | 05:08 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
P
The lojack thing sucks. Just thinking about their ad made me mad. Lo-jack's slogan: "If we can't find your car, we'll pay you the money that it took for you to buy Lo-jack." (can't remember the actual slogan, but that's pretty much it). What kind of wack $h!t is that.
Old Sep 16, 2002 | 05:50 PM
jj uk's Avatar
c240
no uk insurer will cover you unless you have a tracker fitted ...and guess who own the tracker company's.. the Insurance company's
