Driver seat stopped moving forward or backwards
Old Jan 10, 2007 | 10:33 PM
vivaitalia's Avatar
2013 GL450
HELP.........all other movements work, even memory seat works, but when it comes to moving the driver seat forward or backwards, it will not move. There is a clicking sound from the seat adjustment button on the door, and I can hear the relay kick in underneath the seat, but after a few seconds of NO movement, the relay clicks again that's it......no movement. Check the three fuses corresponding to the seats and they are fine.
Any help? Thanks, John
Old Jan 11, 2007 | 02:02 AM
fairladyz's Avatar
2007 C230WZ
Check the seat rail for any loose change, sometimes coins or foreign objects gets stuck inside the slider causing the seat not to move forward or back wards.
Old Jan 11, 2007 | 03:02 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
memory works as well??
so when you push the memory, does it go forward and backwards??
Old Jan 11, 2007 | 04:02 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Is your car still under warranty?
(Please update your profile to indicate what year and model you have).
Old Jan 11, 2007 | 08:46 PM
vivaitalia's Avatar
2013 GL450
No longer under warranty....otherwise I would've brought it in. Nothing stuck in the tracks. Memory will move everything (up/down, pivots, reclines, headrest) EXCEPT the horizontal forward/backwards.
Any other suggestions? I even swapped out the passenger's control box; but no go, completely different part number, even though plugs and box are identical.
Thanks, John
Old Jan 11, 2007 | 09:03 PM
brydon's Avatar
His '06 C350 SS 6MT, Hers '07 C280 S Auto
Thanks, John
So you're absolutely certain everything is plugged in correctly? If one of the cables is loose then it'll not move forward or backward. (Happened on my mother-in-laws C240 Wagon) Can you try swapping the cables from left-right? Sorry, not an expert here just trying to apply my IT-Guy troubleshooting skills
Old Jan 12, 2007 | 07:49 PM
vivaitalia's Avatar
2013 GL450
I switched the driver controller for the passenger only after all other diagnosis failed. Cables are secured correctly.
Anything else? anyone? Jezzz, my toyota has less problems than this benz.....
