how to replace the visor bulb
Old Jan 11, 2007 | 05:32 PM
dnasty8305's Avatar
2003 c240
need help how do i replace the bulb obove the visor mirror the one on the passenger side is out
Old Jan 11, 2007 | 06:00 PM
rlee02135's Avatar
2004 C32 ///AMG
just pry out the cover with a flat screwdriver covered with cloth...
i replaced all of mines with superwhite LED's
sirenebekim's Avatar
Using your clean fingers, remove the bulb housing from the roof from the Right side. My roof has custom upholstry, so it came out probably easier than factory. It just basically clips in and out like the trunk light.
Good Luck
how do those super whites look? I've thought about getting them.. did you use any resistors or anything? What's the part number for the superwhites... I'm goin down the road to get them asap lol
Old Jan 11, 2007 | 07:26 PM
j_belll's Avatar
‘23 EQS AMG
i thought mine was out as well, but wen i took it to the dealer they said just play wit it a little, adjust it. make sure the gold metals are lined up properly and it'll cut back on. so u should try that first.
Old Jan 11, 2007 | 08:12 PM
rlee02135's Avatar
2004 C32 ///AMG
Good Luck
looks awesome at night...
no resistors needed, just take out the bulbs and measure...then buy the LED festoon bulbs in the correct size..i got them from ebay
Old Jan 11, 2007 | 08:27 PM
Arn560's Avatar
Black 04 C230 Kompressor SS
Do you have the bulb number? That would simplyfy things greatly.
Old Jan 11, 2007 | 08:30 PM
rlee02135's Avatar
2004 C32 ///AMG
the bulbs range in size...im pretty sure the dome lights are 39mm, visor lights are 36mm and the map lights are 194 wedge bulbs
Old Jan 30, 2010 | 05:11 PM
mynameiseldin's Avatar
07 C230 Sedan / 01 Mazda 626
Do you know the length of the license plate bulbs?
