Dipstick Measuring tool level
Old Jan 15, 2007 | 03:23 PM
1st lite's Avatar
2002 C240
Just recently I purchased the “Oil Dipstick” measuring tool and the “Transmission” measuring tool for my 02 C240. Would anyone out there have the correct level in “millimeters” for the engine oil when measuring. On my next oil change (2500 kms) I will drain from the pan and then add the 8 litres and do a measurement. For now I am curious to what the correct oil height in the pan should be.
I would also like to know the correct level for the Transmission.
Thanks in advance.
Old Jan 24, 2007 | 03:02 AM
alexinvancouver's Avatar
2011 GL350bluetec
hi, i have replaced radiator on my 2002 c240 and surely enough spilled some tranny fluid. i couldn't beleive mb desiners forgot to design a piece of metal you stick into the tube!
so, went to local mb dealer to purchase fluid and so called "measuring tool". they sold fluid but said they don't sell "special tool". can you believe those freaks!
would you be so kind to tell me what's the measurment from top to the marks please?
thanks in advance.
Old Jan 25, 2007 | 06:54 PM
1st lite's Avatar
2002 C240
Hi alexinvancouver,
To measure the transmission fluid properly, you should have the correct measuring tool. You could measure it with a long flexible metal, or coil rod. Approx. 40"-48" long. Measure your fluid when your vehicle is at operating temp with engine running. Take out the "transmission locking pin" (you will have to purchase a new one of these from MB). Slide your measure tool down the tube until it bottoms out. Level should measure between 55-66mm or (2 1/8" -2 5/8") up from bottom tip of measuring tool. Remember this is with engine and trans. at 80°C (operating temp.).
If transmission is cold (25°C), leave engine running. The trans. oil level should be between 10mm -20mm from bottom tip of measuring tool.
Hope this helps you out.
Old Jan 25, 2007 | 08:11 PM
sirenebekim's Avatar
how is this any better than what the car can check with the computer?
Old Jan 25, 2007 | 10:19 PM
wizkid's Avatar
Ford Pinto
Thanks in advance.
Do your sticks not have marks on them?
Transmission dipstick below. I have a 2002 C240 2.6L Auto
Old Jan 26, 2007 | 12:00 AM
1st lite's Avatar
2002 C240
Hi Eric,
The transmission & engine dipsticks I received do have the measurement marks on them. I wanted to let "alexinvancouver" know the level in inches
& millimeters if he didn't have the proper measuring tool. I didn't know you could check the tranny fluid level from the car computer inside. I only know of the engine oil level reading from the inside of the car. I like using the dipstick measuring tools once in a while just to be sure.
Old Jan 26, 2007 | 12:28 AM
2011 GL350bluetec
Hi alexinvancouver,
Thanks so much 1st lite!!!!!!
Old Jan 26, 2007 | 08:06 AM
wizkid's Avatar
Ford Pinto
Hi Eric,
Got ya.
Btw, are you saying we can check the tranny fluid from inside the car computer? How????
Old Jan 26, 2007 | 09:50 AM
1st lite's Avatar
2002 C240
wizkid,
I wish I knew how to check from the computer. I read it on this thread.
Old Jan 27, 2007 | 12:09 AM
2011 GL350bluetec
Hi Eric,
if you be so kind to give me the measurement from top to bottom i'd much appreciate it. i actually wanted to make my own dipstick for checking it once in a while as you said =o)
thanks.
Old Jan 27, 2007 | 12:49 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by alexinvancouver
...the measurement from top to bottom...
Alex -
The measurements are;
25C: 10.25MM/.425" - 19.5MM/.840"
80C: 54.25MM/2.125" - 65.25MM/2.55"
With the $ investment you've saved on the tool, promise us you're using only #A 001 989 21 03 10 MB fluid.
Good luck!
Old Jan 27, 2007 | 12:49 PM
2011 GL350bluetec
Originally Posted by John Goodlad
Alex -
Good luck!
thanks so much, but it's not about saving a few bucks.
as i mentioned - i went to MB dealership to buy it, but salesman at the parts department said "we don't sell special tools"
i don't know what's so special about it, but i guess those crooks just want my hard earned buck, that's all.
and thinking i'm not gonna give them any makes me happy
10.25-19.5 and 54.25-65.25
but measuring from the top where's the first mark?
thanks!
and yes, i bought that life lasting fluid.
cost $39 a liter here.
Old Jan 27, 2007 | 01:30 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Oil dip stick part #120 589 07 21 00 aprox.$76.00
Transmission dip stick part# 140 589 15 21 00 aprox.$54.00
This is for the m271 motor
Old Jan 27, 2007 | 01:59 PM
splinter's Avatar
Super Moderator
...but measuring from the top where's the first mark?
Oh, that dimension is about 44 inches. As Mercedes designed their #140-589-15-21-00 "measuring stick" to read the fluid level in all manner of chassis/engine/722.6x combinations, it is intentionally too long. It does not seat in the fill tube to obtain its reading. It bottoms against the inside of the pan and reads "up" from there. http://www.mercedesshop.com/Wikka/Trans7226Fluid
Old Jan 27, 2007 | 02:45 PM
wizkid's Avatar
Ford Pinto
Transmission fluid dipstick for the C240 cost me $38.50 from http://www.zdmak.com/
thanks!
Old Jan 27, 2007 | 09:46 PM
2011 GL350bluetec
Oh, ok. that's how it works =o)
thanks.
Old Dec 10, 2013 | 05:35 AM
cc260E's Avatar
E420CDI 2008, GLK220CDI 2009
Thanks in advance.
Hello 1st LIte,
Would you be so kind to post the dimensions of the oil dipstick measuring tool?
with pictures?
In advance many thanks
Old Dec 10, 2013 | 04:51 PM
1st lite's Avatar
2002 C240
Here are the photos of the "oil dipstick" measure tool. Total length (including handle) is 36½" (inches) or 92cm. Close up shot of the lower part of the measure tool shows the oil level markings in millimeters.
I purchased mine from Baum Tools in Florida. I have seem them for sale online at places like RM European, Pelican Parts, Ebay, etc. Hope this helps. Let me know if you need anymore info.
Attached Thumbnails Dipstick Measuring tool level-20131210_133118.jpg   Dipstick Measuring tool level-20131210_133132.jpg   Dipstick Measuring tool level-dipstick_oil.jpg   Dipstick Measuring tool level-oil-dipstick.jpg
