Noob Question
I am in a market for a new car and i am Considering to get Supercharged C class. and i just have a few questions.
1. I want to know if the Superchargers on the C class has IC.
2. Do they use the Eaton M62 Superchargers?
3. Is it easy to change the pulley and Tune the ECU to get more power?
4. what the maximum boost that u guys are running (14-16 psi ?)
5. Can i get the Car in manual transmission or all of them are Auto?
6. What ever model should i go for.
Thanks guys for the help
2. Can't remember which eaton it is, but it is an eaton supercharger
3. Easy to change the pulley?...um, without a pulley puller tool, most likely not. Easy to tune? Well, let's say it's being worked on.
4. It runs in between that range
5. You can get it in manual, if you find it. Not many available out there.
6. Depends on what your intentions are.
K, so now that I've answered your basic questions, do realize that all of these things have been discussed. If you search for each topic (i.e. supercharger, intercooler, eaton, pulley, ecu, m271, boost, etc...)
All of those keyword advanced searches (limited to the w203 forum) would get you some good threads.
