Seat/Mirror memory problem
Old Jan 23, 2007 | 05:08 PM
forane's Avatar
I have an 02 C320 with folding mirrors a la Steve. Recently the drivers mirror has stopped responding to the memory position "1" but seems to react OK to other memory positions. It still functions from the manual positioning switch.
This all seemed to occur after I got an error telling me to check the lamps in the mirror. I found the wires were routed in such a way that they were tensioned in the folding position and both had snapped (one had an exposed end that may have touched the frame). I fixed this with extra wire and heat shrink tubing.
I am stumped on what to look for now. Any suggestions would be appreciated. There is no problem with the passenger side memory response. Is the memory unit for this function that delicate? Does it fail often?
Old Jan 23, 2007 | 07:42 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
When did you get this install? Did you talk to Steve about this?
Old Jan 23, 2007 | 08:59 PM
forane's Avatar
I have not communicated with Steve. My install was the last time he was in Seattle.
Old Jan 24, 2007 | 05:46 AM
SUNILP's Avatar
2015 E250D
the short may have ruined the memory motor or door control unit which stores memory positions. I will be in seattle on Feb 17th incase you need anything done.
Old Jan 26, 2007 | 01:17 PM
forane's Avatar
Where is the memory unit located?
Where will you be in Seattle?
