I searched with no luck!!!I need exact measurements.
2003 c230k sport 4 door
I'm looking to see if I can fit these wheels to my 4 door sedan.
AZA Staggered
5x114.3 / 5x4.5"
Front:
18x7.5" +45mm Offset
225/40/18
Rear:
18x9.5" +35mm Offset
245/40/18
They are coming off a 95/96 240sx RWD.
AZA Staggered
5x114.3 / 5x4.5"
Front:
225/40/18
Rear:
245/40/18
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Our bolt pattern is 5-112 and the offset deppends on what wheel set up exactly, but most range from 30ET to 37ET, without spacers. I am running 19 X 8.5 30ET on the front 235/35/19 tires and 19 X 9.5 35ET rear with 265/30/19 tires. this takes up about as much of the wheel well as possible without major mods, like rolling fenders and etc. To make these wheels fit you would have to use an adapter to change the bolt pattern, at that point the rears would not fit and the fronts would not fit to begin with. Not a good idea. But do what you like.
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
How 'bout you take a look at that new link I added to the Aftermarket wheel thread. That will help you guage.
I added the link to the 1st post in that thread. It's a good thing to check all those threads before starting a new one. You may find the answer without having to post a new thread, which in turn helps us moderators keep old topics from being started. Good luck with the rims.
So I bought some used Stern staggerd wheels but they didn't FIT!!!!!!!!
The hub? I guess was to big for the rim to go over.
Maybe I can take them to a machine shop and bore them?
Do a search on google for Hub Centric Rings. Many aftermarket rims need them. These are not spacers. Search on google for spacers vs. hub centric rings.
