Service A,B and C - Whats involved in each?
Old Feb 12, 2007 | 04:08 PM
Fai+H777's Avatar
ML55 AMG
I know this qsn will sound simplistic to many but I have no idea what each involves.
I had asked the mechanic to change my oil check the fluids and filter and now it says Service B due in 7 days.... So I'm not sure what that entails.
Gratitude is extended in advance
Old Feb 12, 2007 | 04:15 PM
e1000's Avatar
a quarter mile at a time
it should be in your manual. I can post it if you don't have one
Old Feb 12, 2007 | 04:17 PM
Fai+H777's Avatar
ML55 AMG
Please do. Mine is a Japanese import....
Old Feb 12, 2007 | 04:26 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Have you searched at all? I know that people here say you are not C230_617, but dam your questions are so C230_617.
E
Old Feb 12, 2007 | 07:00 PM
Fai+H777's Avatar
ML55 AMG
E
Lol. How insulting! Sorry, I'm not that clued on with cars.
Old Feb 12, 2007 | 07:48 PM
e1000's Avatar
A-Service
What we do:
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2007 vehicles are equipped with the Flexible Service System (FSS)
B-Service
What we do:
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
