check engine code
Old 02-15-2007, 09:24 PM
ChaRgeC230's Avatar
05 c230 SS
check engine code
Hey guys i just got a CEL so i went to pull the code and it was p0171 and p0600.. so i know the maf sensor is messing up.. my question is..is it covered under warranty if the sensor is faulty? Im takin the car to the dealer tomorrow.
Old 02-16-2007, 01:08 AM
Buellwinkle's Avatar
Abolutely covered under the 4/50 factory warranty, don't even mess with it.
Old 02-20-2007, 11:58 PM
1stBenzo's Avatar
07 C230 Sport Sedan Orion Blue
I was having problems with the car hesitating or not starting at all when it was cold. Yesterday the CEL came on for me but I thought it was because I was low on gas which can trigger that. I filled up and tried what the manual recommended to remove the CEL and it didn't work so I came to the conclusion that it probably wasn't because of low fuel. I took it to the dealer today and they said something about the MAF sensor. It is getting colder again so that will be the true test if it is now fixed or not. The CEL is gone and whatever they did today was covered as well as a C280 4matic as a loaner car for the day. Good luck with your problem and keep us posted!
1stBenzo!
Quick Reply: check engine code
