spring intall
Old Feb 22, 2007 | 08:25 PM
stevenle21's Avatar
spring intall
hey guys sorry to ask you this but does anyone have a write up of intalling springs for a 2003+ c class ss ?
i tried searching but nothing came up that would have been any help
thanks guys
Old Feb 22, 2007 | 08:55 PM
SUNILP's Avatar
2015 E250D
I'm not sure if there is a write up but if you need something specific explained let me know and I'll see if I can write on it. You will need a special tool to remove the special nut on top. Also, a suitable spring compressor or a shop that has one. I find brannick wall compressors the best for this purpose. The top three nuts can come off as well as the lower nut and bolt. The entire strut assy will come out with spring. DOn't worry, it won't fly out.
Old Feb 22, 2007 | 09:37 PM
mbarrad's Avatar
2005 C230SS
thanks guys
I thought I was alone. I searched but could not find any write-up. I need to change out my springs so I will do a write-up with pics when commit. The suspension sticky should contain instructions, but it does not.
Old Feb 22, 2007 | 09:40 PM
mbarrad's Avatar
2005 C230SS
Where can I get this tool? Would I need a spindle spreader tool to get the base of the strut out of the spindle? Do you still live in Houston? Thanks!
Old Feb 22, 2007 | 09:48 PM
stevenle21's Avatar
i got it torn apart but im having a problem getting the top on the spring! just removed everything with regular tools. hopefully i didnt mess anything up.
so how do i get the top back on to the strut i have? i compressed the spring all the way down but it wont thread. theres a small aluminum ring that threads but when i took it apart i didnt see how it went.
Old Feb 22, 2007 | 09:50 PM
stevenle21's Avatar
there are three bolts holding the strut to the spindle. two really small bolts that are right behind the disk, and one large bolt that requres a large hex.... so no spindle remover requried
Old Feb 22, 2007 | 10:16 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
"...theres a small aluminum ring that threads..."
Which piece is giving you a tough time?
Old Feb 22, 2007 | 11:16 PM
mbarrad's Avatar
2005 C230SS
Great to hear. Looks like exchanging springs will be easier than I thought.
Old Feb 23, 2007 | 01:04 AM
coin's Avatar
'06 CLK500
Anyone knows which is our spring pad on the picture above?
Old Feb 23, 2007 | 01:19 PM
stevenle21's Avatar
no idea what spring pad that is but finally finished the front lastnight and the rears after the thunder storm this weekend. my 2003 had a 4 finger gap and is now down to 1.5 its awesome. hopefully the rears go easy.
you should really have a buddy help you, the more hands you have the easier the intall will go
Old Feb 23, 2007 | 11:00 PM
mbarrad's Avatar
2005 C230SS
What springs did you install stevenle21? Did you keep your OEM struts and shocks?
Old Feb 24, 2007 | 12:06 AM
SUNILP's Avatar
2015 E250D
I will be in houston soon. The tool is available at your dealer.
Old Feb 24, 2007 | 12:22 AM
stevenle21's Avatar
i bought h&r springs, they look really nice but the spring compressor tore up the outsides a bit. yep OEM struts and shocks, they still had some life in them. im too cheap to buy new stuff
Old Feb 24, 2007 | 08:01 AM
WaveyKat's Avatar
Something Slow
this is the tool to remove part number 160 from the above picture
Part Number 203.589.00.07.00
Old Feb 24, 2007 | 10:35 AM
stevenle21's Avatar
all i did was compress the whole spring as much as possible then took the cap and spun it. theres so much pressure it spins it loose i guess, and when put it back together i just pushed the cap down again and started it by hand and the cap spun it tight till the bottem.
