Sound System Complete!!
Old Apr 2, 2007 | 10:21 PM
raklert's Avatar
C200K W203
Originally Posted by W0n6_3d4n
Some may ditch Dyn because of their somewhat lack of detail and accuracy, but when listening to music, it's the emotion that count. This is where Dyn excel, attack and decay is amazing. Are u running pasive or active??
Emm i am not sure probably a passive crossover. I agree with you about the dyna. Before i purchase it i listend to Boston Z6 (top reference line). The boston is extremely accurate and extremely bright in every detail. Its catchy at first but i find it boring after a while. Thats how i ended up with dyna (its cheaper too haha) How do you fit the 7" woofer on your door?
Old Apr 2, 2007 | 10:26 PM
raklert's Avatar
C200K W203
Originally Posted by rlee02135
is it me or dd you misspell Kleemann?
haha Rlee you notice it. The guy who cut the acry;lic miss spell the Kleemann.(an N is missing) But i felt sorry for him, it took a long time polishing that thing. haha doesn't bother me much though.
Old Apr 2, 2007 | 10:32 PM
rlee02135's Avatar
2004 C32 ///AMG
yeah...no big deal.
not a lot of people will notice.
Old Apr 2, 2007 | 10:42 PM
raklert's Avatar
C200K W203
Originally Posted by MiKeSSw203
Very nice! You should get a Bruce Lee action figure and place him in there
bro is that a racist comment? If it is then that ain't cool Mike
Old Apr 2, 2007 | 11:12 PM
W0n6_3d4n's Avatar
C200K (w204)
With a door pod, i believe you can fit 8 inch there, but depth will be an issue, one way to get around it is to remove the speaker grill on the door and mold it somehow. That'll be my next project if i decided to go for 3 way system. How do you find the midbass from those 6.5??
I need to treat my door with a lot of sound deadening + foam to get it sound right. Dyn woofer is rather hard to work with, but once done correctly, awesome, sometimes i listen without a sub, very crisp albeit can't go very low.
Old Apr 3, 2007 | 02:10 AM
ChristianJan's Avatar
c230 Kompressor Coupe
That looks awesome man good work.
Old Apr 3, 2007 | 02:15 AM
  #32
raklert's Avatar
C200K W203
a 3 way system will produce better mid range but its hard to do, i would love to see it when you done. The mid bass on Esotec is quite good actually. Works just fine with bandpass box set up.
Old Apr 3, 2007 | 03:01 PM
  #33
TruTaing's Avatar
Moderator Alumni
w203 m112
I saw this post first thing yesterday, but forgot to say how hawt it is...
Old Apr 4, 2007 | 08:49 PM
  #34
LorinserCClass's Avatar
The True OG Modded out W203
Nicest 'new age' W203 set up I have seen lately Big Boys go 12" though
Old Apr 4, 2007 | 08:56 PM
  #35
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
Zooommfggg!!!
1000 Posts Biatch!!!
Old Apr 5, 2007 | 12:20 AM
  #36
Midnight Koop's Avatar
CL203
i didn't know "X to the Z.. x-zibit" pimped rides down in bangcock... niiiiice
Old Apr 5, 2007 | 12:40 AM
  #37
PhilipM1's Avatar
1993 190E 2.6
S . I . C . K
Old Apr 5, 2007 | 05:23 AM
  #38
diamondblak05's Avatar
Too many to list
Everything looks great and professionally done, but not feeling the deck and EQ. Looks out of place and not flush IMO. How's the sound? Any vibrations from the trunk? I have a 10" sub in the back and it vibrates like crazy when I crank up the volume. Any ideas on how to get rid of the vibrations? Thanks.
Old Apr 5, 2007 | 07:08 AM
  #39
tommy's Avatar
2004 Civic Si. FWD for the Win!
With that much black plastic around the radio, it doesn't look good against the brown wood trim, imho. Would be better to swap out the trim for aluminum or something more custom. Otherwise, looks great.
Is it the shadows of the pic, or does the top part of the plastic dip in where it meets up with the wood trim?
Old Apr 5, 2007 | 01:08 PM
  #40
cla 1000's Avatar
2002 C230 K, 6 speed
u spend all that monney. U should get rid of the Alpine unit and get a double din touch screen one. Alpine actually has a very nice one. It would look a lot better, cleanner.
Also the speakers u aded on the dashboard look out of place.
Sory but that is my oppinion.
Old Apr 5, 2007 | 06:26 PM
  #41
W0n6_3d4n's Avatar
C200K (w204)
Most double din unit is flash and no good if you are after sound quality. That particular Alpine is very good for the job. Add few Dynamat and fat foam in the trunk lid, and wedge open the ventilation grille on the each side of the boot with closed cell foam to keep it from flapping when bass note hit, that'll do the trick. Oh some reinforcement on the plate number too.
Old Apr 5, 2007 | 11:23 PM
  #42
Fai+H777's Avatar
ML55 AMG
Old Apr 6, 2007 | 12:05 AM
  #43
raklert's Avatar
C200K W203
I agree thanks for your comment. As far as my system goes the Alpine Deck is the weakest point. However, the Zapco does help boost up the signal considerably and I want to enjoy my system for a bit before upgrading the deck to Pioneer P90 or Clarion HXD2. The Alpine double din W200E is a nice head unit, but its sound is no match for the P90 or even the cheaper Clarion HXD2. If your system is strictly for music, then you should stay away from the double din monitor head unit, but if you want 5.1 surround sound then the Alpine W200E couple with Alpine digital processor H701 is the best choice.
Old Apr 6, 2007 | 12:51 AM
  #44
raklert's Avatar
C200K W203
Did you damp your car? You should damp the trunk and the lisense plate with Dynamat. If it still shaking then I think your problem could be from the box. What kind of box do you use?
Usually sealed box takes up more wattage from the power amp and if it is powerful enough it shake the car loose when you crank it up!! Sealed enclosure is best for movies and Sound Quality application. If you wanna go loud, sealed box is not the way to go. What you need to do is check your amp if its powerful enough for the sub and change the box design to either ported or band pass and make sure they use thick 24mm PCM wood!!
One thing to keep in mind about ported box in our benz is that our rear seats are foam and plastic and its harder for the bass to get through unlike japs car. So, the bass from ported box will loose it strength traveling in to the passenger cabin. As a result you will hear the bass "inside the trunk" not in the passenger cabin with ported box. So in your case i would recommend you to mount the 10" sub the same location of stock sub. Or if you want loud bass(less accuracy) then go for bandpass box. hope this helps
Old Apr 6, 2007 | 03:33 AM
  #45
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
love the trunk setup except the head unit and the EQ...looks 90's.
I would seriously get on their *** for making you a Kleeman enclosure. lol but if it doesn't bother you then all good.
Old Apr 6, 2007 | 04:24 AM
  #46
raklert's Avatar
C200K W203
Thats a good idea Frank, may be i get them make Polish Aluminum face for my deck with Kleemann lazer engravings. However, would you think it would match with my wood trim interior??
