drivers door lock going crazy????
Super Moderator
...just take it to the dealer...
Hey, that reminds me, I'll need some KY when the SA delivers the good news.
same problem in my clk. any updates?
Is there an actual actuator that can be replaced or is it the door lock?
Part number would help if it's an actuator.
2002 C230K, 2013 BMW 328, 2015 BMW X5
There are threads around here that have DIY info.
E
I just did this repair on my 2003 cl230 instead of drilling any rivets i decided to take out the back door speaker located directly below the door lock. I then proceeded to use tin snips and enlarge the speaker hole in just one location staying clear of any mounting points or large braces. I also used pliers to bend the metal to enlarge the area i cut further which saved me from removing any more material. I was then able to slide the actuator out of this spot. The orientation that I found the best was to turn the actuator upside down so the door lock pin was on the bottom left coming out the speaker hole.
I then just bent any metal back flat.
I hope this helps it was surely easier then drilling rivets and messing with an airbag.
