Fuel Filter
Old Apr 13, 2007 | 03:56 PM
Jkw's Avatar
Jkw
2004.5 C 230
Fuel Filter
The dealer wants $250 to replace it,
is the part that hard to get at?, Could I do it myself?
All advise appreciated, Thanks
Jkw
Old Apr 13, 2007 | 04:51 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
If you have a jack and stands, basic tools, not a problem. The dealer price for he filter is $130.00 but I have found them for $36.00 for Bosch OEM part. Just need the filter and four small hose clamps and about 1 hour at the most.
Part ://replacement.autopartswarehouse.com/parts/autopartswarehouse/quote.jsp?year=2004&product=E1000-60921&application=000715518&part=Fuel%20Filter&dp= false
put http in front.
Old Apr 13, 2007 | 05:18 PM
JesLet's Avatar
2002 c 240
That fuel filter is located in the rear, close to the driver side, rear wheel, take off the plastic cover and you'll see an aluminum canister. I prefer Mahle than Bosch if you want to save money.
www.installuniversity.com --- DIY of fuel filter removal.
www.buymbparts.com -- Mahle fuel filter.
Old Apr 13, 2007 | 05:42 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Anyone know how often does the fuel filter and pump need to be replaced?
thanks,
Old Apr 13, 2007 | 08:59 PM
alexhui's Avatar
I think fuel filter is mileage dependent and should be changed every 60,000 miles.
I figured 60,000 miles usually means 5 years.
So I changed my fuel filter after 5 years at 72,000 miles.
Old Apr 13, 2007 | 09:18 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Thanks, after reading the diy on installuniversity... its time to replace mine!
Old Apr 14, 2007 | 10:15 AM
Jkw's Avatar
Jkw
2004.5 C 230
Thanks guy's,
I think I can do it myself.
My car is 3 years old with 63,000 miles so I'm due.
I found the Bosch filter for $46 on line, sounds good to me.
Thanks Again
Jkw
Old Apr 14, 2007 | 01:14 PM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
When i looked to purchase one, i noticed that there are two options. One of them is for cars that come with a bosch filter and the other is for those that come with the Krecth (i'm not sure on the spelling). I'm guessing the easiest way to find out is just to look at mine first? Or is there another way i can tell? It has something to do with the VIN doesn't it?
Old Apr 14, 2007 | 03:06 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Originally Posted by Jkw
Thanks guy's,
Thanks Again
Jkw
There's a DIY around here, or maybe on the 'other' site.
Basically put the car on ramps in the back,
undo a couple of the nuts for the plastic cover(not even the whole thing) , wedge it open with a screw driver, put something under the car to catch any spilled fuel, put on safety glasses just in case fuel sprays in your face, put clamps on the fuel lines of some sort to keep fuel from running out, pry the funky clamps off with a screwdriver, undo the bracket insert new fuel filter, swap lines from old to new filter with new clamps from local hardware store, tighten clamps, redo bracket, turn on ignition, wait 30 seconds for system to pressurize, start car.
It may sputter for a few seconds, and possibly throw a check engine code (mine didn't). Once it's running, rev a little, check for any leaks,
reintall cover, drive away. Clear CEL with OBD scanner if neccessary.
Takes about 1/2-1 hour, mostly due to prying off funky OEM clamps.
They're a PIA.
Bought my Bosch filter locally for 35 bucks.
