Crack Shaft Leakage After Installing ASP Pulley
Rating: Thread Rating: 20 votes, 5.00 average.
Old Oct 4, 2002 | 06:50 PM
  #51
20FHK02's Avatar
2002 C230 Coupe
Originally posted by Matt230K
I looked at my Kleemann and noticed that it is rubbing also. I am going to take a closer look at the belt tomorrow to see how bad it is. It kind of looks like it has already worn as much as it is going to, just a little bit off the end, and only through the top layer, so the full width is still in contact with the pulley. It didn't look frayed at all.
Anyone know if this is okay, as long as it doesn't wear anymore?
Maybe I should get this new ASP pulley instead.
I would send the pulley back to KLEEMANN and tell them to make it smaller. Several hundredth of inches tolerance variations in the assembly of engine accessories on the outside is normal for my acceptance level. So a tight pulley that does not rub on one engine might rub on another engine.
I will trade the <1hp reduction in gain for a bigger pulley clearance.
Old Oct 4, 2002 | 07:02 PM
  #52
Matt230K's Avatar
2010 C300 4matic
So you think I should return it and have them redo it or just get a new ASP? I'm all for the cheaper price, although I was happy with all the information I got from the guy from Kleemann before deciding to buy it. This was before I found this forum.
I did get them to give me a parts warranty even though I installed it myself since I had it done with help of an MB tech.
Or maybe I can just get a thinner belt? What do you think?
Old Oct 4, 2002 | 07:40 PM
  #53
firstkill's Avatar
I was told by Lee that it only rubbed if the belt was a little thick. So both pullys work fine, it just depends on th belt. I was told that the new spec pully will work with any belt.
~fk
i am waiting for hte new spec pully. He told me that it wont be all black. Part alum and part black
Old Oct 4, 2002 | 08:17 PM
  #54
linh's Avatar
99' SLK 230 & 01' CLK 430
Guys,
This is all Buellwinkle fault !!! He wanted a pulley that is bigger then any other pulley out there and so that's what happen why the belt rubbed. I talk to Lee at ASP about this three days ago concerned of the problem. So he's going to make the C coupe pulley a little smaller. But the 98-99 pulley will not have this problem because the factory pulley is already a little smaller then the C coupe factory pulley.
Old Oct 4, 2002 | 08:21 PM
  #55
20FHK02's Avatar
2002 C230 Coupe
Maybe it's because the belt I have is the heavy duty version, so I guess if you get the regular duty one it won't rub. Just a guess though.
Old Oct 4, 2002 | 10:06 PM
  #56
Buellwinkle's Avatar
Yes, Linh it's all my fault, I admit it, greed for power got the best of me although it doesn't rub on my car.
Old Oct 4, 2002 | 10:14 PM
  #57
linh's Avatar
Lol....sorry buddy !!! Just tell it like it is !!! I know your does not rub but we can barely slight a piece of paper through your.
Old Oct 5, 2002 | 12:30 AM
  #58
20FHK02's Avatar
2002 C230 Coupe
Yea! He is just luck out because I am using the same $18 belt from Pep Boys as his.
Old Jan 17, 2003 | 01:49 PM
  #59
TaiwanBoy's Avatar
Hey.. do you think my leakage was because i broke the seal.. Or do you think its my pulley??
Old Jan 17, 2003 | 01:59 PM
  #60
Return the pulley to ASP, some where made where the hub surface was not polished perfectly and that caused a small leak, Lee promised to quality check each one personally because of this. They will replace it with the newly design stainless steel hub and you'll be better off anyway.
BTW, 8,000 miles and it never leaked 1 drop of oil and I've had it on and off a few times.
Old Jan 17, 2003 | 02:16 PM
  #61
TaiwanBoy's Avatar
Is it safe.. to drive with a leak.. as long as i keep the oil levels up... And also.. Is it hard to break the seal.. Cus i'm not sure if its the pulley causing this or the seal breaking.. Sorta confused.. So any advice would be NIce thanks guys.. btwthe pulley kicks ***
Old Jan 17, 2003 | 02:25 PM
  #62
I've never heard of a pulley damaging the seal, if you put the factory pulley back on it will stop leaking. The small amount of oil is not a problem, just keep an eye on it until you are ready to take it off and send it back in.
Old Jan 17, 2003 | 02:32 PM
  #63
TaiwanBoy's Avatar
how much is it to replace the seal.. if i did break it.. And also.. Would have have to pay for shipping back to texas... and aslo pay them to ship it back.. or is LEe going to pay for all the shipping
Old Jan 17, 2003 | 05:29 PM
  #64
hobie's Avatar
'02 C230K
My early ASP has always leaked a drop or two. I can live with it vs. labor $ to R&R for an automatic, and whinning tio Lee. Power is intoxicating. Just had the dealer install the rear AMG bar. Thank you to the forum! Turn in is much improved, have yet to bansai a cloverleaf...it's snowy. Yoko AVS's are a riot in the snow, like slicks on olive oil. I should pony up for snows, but I'm having too much fun going sideways.
Old Jan 17, 2003 | 06:03 PM
  #65
Hobie, I had the rear AMG for a while and it's great but when I did the front (same price as rear) it improved it that much more.
Old Jan 17, 2003 | 06:06 PM
  #66
TaiwanBoy's Avatar
did the c-coupe come with it stock.. not the amg one
but did it come with stock sway bar or rear bar.. I know when my friend lifted my SLK .. i commeted taht i had a really thick sway bar in the front.. Oh yea btw Buel.. What kind of Plugs should i get.. Did you get any urself? and where to get it at.. Thanks
Old Jan 17, 2003 | 06:09 PM
  #67
20FHK02's Avatar
2002 C230 Coupe
Are you saying that ASP has already implemented the new all steel hub design to the future pullies?? I have the alloy pulley laying around in the garage...
You have already rated this thread Rating: Thread Rating: 20 votes, 5.00 average.
