M271 - MAF Cleaning - HELP
Lets first find the MAF, the figure out how to get it out.
Is what I have unplugged the MAF?
If so, there are 3 screws holding it to the airbox, yet all 3 are a PITA to get to! The lowest one (left side in pic) I cannot get at with a screwdriver, the braided hose is in the way.
Any tips appreciated guys.
OK so that is the MAF, no the problem is MB PUT A SCREW ON THE BOTTOM of the pipe that connects to the air box that surrounds the MAF.
WTF! How am I supposed to get at that screw to get the pipe disconnected form the air-box?
Or is there a way to get the sensor out without removing the pipe?
EVE
It's some work, i'll tell you that much . Just be patient.
EVE
Disconnecting the ECU may help a bit and vice versa, removing the airbox for more room might help in ECU removal. You'll need ratchets and extensions for this job - I think I've done this about 7 times on someone's car lol.
You have to take apart the whole airbox. You need some inverted torx bits to take out tthetwo bolts in the holes. Then you slide the airbox forward (with lots of nudging) and it comes free. After that's free, then take T25s to take out the 3 holding the MAF assembly.
I saw 2 rubber pieces that the airbox seems connected to on either side, does the airbox simply clamp onto these?
So basically its free right now, I just need to pull forward. I will report more progress in an hour.
Should I disconnect the battery before disconnecting the ECU?
2002 C230K, 2013 BMW 328, 2015 BMW X5
I can't answer your question on disconnecting the battery before the ECU. But remember, people get faults when disconnecting there batteries.
If you are looking to clean the MAF, clean it in place, let it air dry for about 2 hours, then put it all back together. The MAF cleaner dries really quick.
If you are replacing it, that is another mater entirely.
E
E
You mean spray it while its in the car? Its behind a plastic grid, and I don't really want to spray crap into my intake.
Success! except...
The ring clamps that hold the downpipe to a rubber section. Any tips on how to release them? and more importantly re-clamp them afterwards?
Going to the hardware store to look at them and see if there's a tool I can buy (plus I need a 27mm socket for the oil filter).
2005 C55, 1988 260E, 2000 Chevrolet Silverado
You have to use a long pair of bent needle noise pliers or the Mercedes tool. Craftsman makes a pair of the special plier for this style of clamp to. About $35, If you are going to work on your car alot you might invest since most of the clamps are this style. I removed my clamp and replaced it with a stadard screw style when i did my Kleemann kit because it makes it easier to use a 1/4 extension and just unscrew it. I remove all the wires and plugs, undo the large vacume line by pinching it at the lugs on each side and pulling up, undo the two airbox mounts, and then the clamp on the down pipe. You lift up in the back so the down pipe clears, then move back tward the firewall tell the front mounts come loose of the rubber recepticles. then lift it forward and come straight out with it. this takes only a few minutes to do and if you remove the airbox it is esier to remove the ECU then try to unscrew it in place.
If I could've gotten the metal clamp undone, its really a 10 min job. I'll do my best to take pics next time and write up a DIY, since I needed my car and put it all back together without getting the MAF out.
I plan on working on my car more often, so I'll look up that tool, although with the size of the area to work in, a screw style clamp would work so much better.
With the amount of engineering put into ths car, someone could've designed the pipe around the MAF to make it easily removable. I'm surprised at how over-engineered this car is, yet not for easy maintenance and repairs.
E
1 Post
C230 KOMPRESSOR (2003)
How to remove Maf on 2003 C230K
Hey everyone!
I am looking for the maf on the 2003 c230K coupe, i have spotted it after i took out the air filter cover. It is located on the drivers side way at the back in 03 c230 k. I unplugged the cable and unscrewed the screws but it seems like maf on this particular model is not all that accessible. I dont know how to take it out. I have checked this forum thoroughly and it seems like a pretty easy job on other models but this particular model seems a bit tricky, any help will be highly appreciated. Any pics will help alot.
Thanks alot guys in advance.
1 Post
Thanks E
I have searched this forum and benzworld.org forums thoroughly. I didnot come across any information particular to 2003 C230 K coupe. I would really appreciate if someone cud help me here.
Thanks.
Thanks.
Search on my user name, I posted a topic with pics a few weeks ago.
https://mbworld.org/forums/showthrea...&highlight=maf
C200K W203
Why do you guys even bother to clean the MAF. The extreme heat at the MAF will burn every partical that went through there. ie. it wont get dirty. If you take out the MAF you risk ruining the MAF, i would say its better to leave it alone.
I found an online distributor for $129 USD, so I'm just going to replace mine instead of continuing to clean it.
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I cleaned mine and resulted in a waste of time, better off replacing with a new once you're there.
