More suspension issues....
Old Jan 23, 2007 | 06:12 PM
rpayer's Avatar
C320
Busted suspension with only 36k???
Guys...
Does 36,000 sound a little early for having to replace almost the entire front suspension... Thrust arms, control arms, bushings, etc.... The dealership is telling me this is going to be almost $2,000 and I'm under warranty!
Old Jan 23, 2007 | 06:13 PM
Mercus's Avatar
2006 C230SS Blue/Black, 2003 SL500 Silver/Black
I can't believe that....second opinion......
Old Jan 23, 2007 | 06:15 PM
advans's Avatar
C55 ///AMG, 535xi
do you drive on unpaved, (new york city like, potholes) roads all the time?
I've replaced my rear shocks abt...12,000miles ago. I only have 37,000
Old Jan 23, 2007 | 06:19 PM
drivethebenz's Avatar
05 C230
Will warranty cover the cost ?
Old Jan 23, 2007 | 06:21 PM
rpayer's Avatar
C320
Second opinion where? There is only one MB dealer in Baton Rouge. Something is defenitely wrong with it. Thats why I brought it in. Its just crazy to me that this type of work would be required with only 36k on the odometer.
MB-BOB's Avatar
Admin Alumni
See Garage
Originally Posted by rpayer
Guys...
Replacing bushings, yes. This is a known issue. Replacing control arms (other than bushings) is the dealer soaking MB for the warranty work.
I was told the new bushings were an "improved" design. They should be installing the "new" design on the newer cars too, but I keep reading about bushing wear on the newer cars regardless. So, I'm getting skeptical that the "new" design is any better, if not the same as the old.
Old Jan 23, 2007 | 06:28 PM
rpayer's Avatar
C320
doesnt look that way...
Old Jan 23, 2007 | 06:29 PM
rpayer's Avatar
C320
sure dont man... i baby it. i'm in baton rouge. our streets aren't the best in the world but they're not that bad
Old Jan 23, 2007 | 06:30 PM
BKLYN_C's Avatar
MB
This is starnge, but the dealer did replace my front bushings. And it was covered by warranty. Regarding the shocks I don't know, but 12,000 sounds like just 1/10 of what they are rated for even in NYC. But the entire suspension for $2K and not covered . That doesn't smell right. Just like $10K for an airbag
Old Jan 23, 2007 | 06:33 PM
rpayer's Avatar
C320
Milking the warranty is fine with me, I paid for it. The problem is they are going to try to make me pay, not the warranty...
Old Jan 23, 2007 | 06:43 PM
rpayer's Avatar
C320
I concur
Old Jan 23, 2007 | 06:45 PM
Mercus's Avatar
I would tell the dealer that I was going to confer with MBUSA on the issue in order to ascertain whether or not this is a warranty issue....that should get the truth out fairly quickly.....
Old Jan 23, 2007 | 09:04 PM
rpayer's Avatar
C320
How would I go about doing that?
Old Jan 23, 2007 | 09:33 PM
BKLYN_C's Avatar
MB
call 1-800-MERCEDES and tell you story
Old Jan 23, 2007 | 10:20 PM
W Cole's Avatar
makes your daughter horny
Unless you ran over something/went offroading this should be 100% covered under warranty. If this happened to me I would be furious...
Old Jan 23, 2007 | 11:07 PM
mleskovar's Avatar
'17 Jaguar XF
+1
Old Jan 23, 2007 | 11:10 PM
rpayer's Avatar
C320
Thanks!
Old Jan 23, 2007 | 11:14 PM
rpayer's Avatar
C320
I take very good care of this car and considering the condition of the car when I bought it a little over a year ago, the previous owner did too. Even if its aftermarket? Bumer to Bumper but still aftermarket... Believe me, I am furious!
Old Jan 23, 2007 | 11:24 PM
W Cole's Avatar
Did you modify the suspension? If so then they most likely won't cover it under warranty..
My buddy has an e46 beamer with TKlein (sp?) Coilovers, sways, etc, etc.
He just brought it into the dealership this weekend with three broken wheel bearings and several worn out bushings. Understandably, NONE of the damage was covered under warranty.
Old Jan 23, 2007 | 11:34 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
I HATE POT HOLE!!!
Old Jan 24, 2007 | 01:20 AM
Blake P's Avatar
'09 A4 S Line
Just had my front bushings replaced under warranty and I have aftermarket suspension. I can't see any reason why they shouldn't cover the faulty bushings under warranty.
Old Jan 24, 2007 | 09:18 AM
rpayer's Avatar
C320
My suspension is completely stock. I meant the extended warranty was "aftermarket". I will be contacting the dealer shortly. I plan on getting to the bottom of this today.
Old Jan 24, 2007 | 10:28 AM
rpayer's Avatar
C320
Well I just got the phone with the SA. It appears that they are not budging. This is the second time the car has been in for "wandering" mirrors. They say they cant reproduce it yet I have to hit my memory button almost everytime I start the car. The are trying to charge me $225 for the weather stripping on the passenger side door... $125 for a wiring harness and a bulb because I am getting a "Rear tail light out" message but yet there is no rear light out. And then there is the suspension.... SA said the bushings failed and lots of other stuff failed because of it.... I told him that I had heard that the bushings failing was a known issue. He said he had never heard that. I also stated that I would be requiring a second opinion and contacting MBUSA if my warranty does not cover this. That didn't make him too happy. I'm sorry to say it guys but this is about to push me over the edge. I will be headed to the Acura dealership at lunch to look at a few TL's... It's just getting rediculous. Its like every 6 months the car goes to the STEALERSHIP for $3k worth of repairs and its there for 2 weeks cause they have to fight with the warranty company because they dont want to pay because the STEALERSHIP has milked it so much its $3000.
Old Jan 24, 2007 | 05:46 PM
rpayer's Avatar
C320
The SA is telling me there is no service campaign regarding the bushings in the front suspension. Does anyone know if this is true or not??? If so what is the campaign number?
Old Jan 24, 2007 | 05:58 PM
W Cole's Avatar
Hey man, sorry I dont know about a service campaign. But that is absolutely rediculous that they would charge you for these things. They are covered under the warranty. Honestly, Its making me angry just reading this..
Try going to a different dealership?
