replacing one rotor?
Old Apr 27, 2007 | 01:01 AM
jdestreza's Avatar
is it ok to replace just one rotor in the rear of a 2003 c240 4matic? dealership said not a good ideza but mechanic said it doesnt matter. i mean its only $70+ for the rotor right so i dont mind buyinh two.,, thanks
Old Apr 27, 2007 | 01:03 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
hmm maybe do 2 balance them out???
or stealer want money??
Old Apr 27, 2007 | 01:20 AM
jdestreza's Avatar
i think stealer want money!! my mechanic from m-tech said it should be fine.. anyone knows if this is so? brabus, do you know if rotors are only $70 for one piece?
Old Apr 27, 2007 | 01:29 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
i wouldn't just replace one
i would replace 2 at the time
Old Apr 27, 2007 | 02:21 AM
tozfeekum's Avatar
buy those brembos or c32 brakes !
Old Apr 27, 2007 | 10:23 AM
jdestreza's Avatar
i wish lol . too pricey for me right now. Maybe in 6 months
Old Apr 27, 2007 | 11:20 AM
JKETCH's Avatar
THE C
Do both if you are going to do it. You might as well do it right!
Old Apr 27, 2007 | 12:09 PM
Buellwinkle's Avatar
The theory with drum brakes (what's on the inside of the rotor) is that if one drum is more worn than the other and the diameter is different it will have different braking properties and you could spin out if you have to depend on your emergency brakes to stop. In reality, not likely to happen, the drums barely get used at all. As for the disc rotor side, until the pad beds to the new rotor, the braking characteristic will be different so be careful the first few hundred miles.
Old Apr 27, 2007 | 02:59 PM
jdestreza's Avatar
so I guess it will be just a lot smarter to replace both so I wont expect anything. I mean most likely nothing is going to happen if only one is replaced but there is still a chance even if its only 1 out of a 100 chances right?
