Question
Old May 12, 2007 | 02:46 PM
romz's Avatar
2001 C240
Question
Hey guys,
I just needed some help I was wondering if rims with these specs fit an 01 c240?
19X8.5 - front w/ 2" lip
19X9.5 - rear w/ 3" lip
Offset - 35 (all 4)
Center bore 66.6
Bolt pattern 5/112
Any help would be appreciated.
Old May 12, 2007 | 02:58 PM
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
Yeah they'll fit, but the front's ET is too big if you're planning to get COs.You won't be able to SLAM the fronts if that's your plan
Old May 12, 2007 | 03:03 PM
romz's Avatar
2001 C240
Thanks for the reply but I dont mean to sound stupid but Im not sure what you are talking about.
Old May 12, 2007 | 03:38 PM
B189s's Avatar
It's alrite. What I was saying if you're planning to get an aftermarket suspension specifically Coilovers (adjustable height and dampening maybe),you won't be able to lower your fronts that much since you have ET35 front wheels (means your wheels is too close to the suspension),it can cause the wheels/tires will rub against the suspension.
But the wheels specs you mentioned will fit perfectly with your stock suspension .Although it might rub a little on the rear when you hit bumps since stock suspension is just plain soft (I am assuming you don't have Sport Sedan suspension)
Hope it helps and GL
Old May 12, 2007 | 04:07 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
it'll fit, but like nibo83 said, with coilover, it might rub. However, spacer can take care of that. I have the similar set up with 10mm spacer in the front, no vibration, ride just fine.
Old May 12, 2007 | 06:03 PM
B189s's Avatar
You have ET35 for your front wheels and using 10 MM spacers?! .Any rubbing against the fender?(Coz you have a pretty aggressive ET now, 25)
Old May 12, 2007 | 08:07 PM
romz's Avatar
2001 C240
wow thanx for the help guys I dont plan on getting after market suspension anyways so for the stock suspension that comes with the c240 you are saying that I will have no problems
Old May 12, 2007 | 08:32 PM
B189s's Avatar
NO,but I think it MIGHT rub a little on the rears due to soft suspension
Old May 12, 2007 | 08:40 PM
romz's Avatar
2001 C240
Alright thanx for the help bro Ill call up the dealers on monday and ask them so I dont go and waste my money on something that will not fit.
