Stock Air box structure.
Well, luckily I was about .2 miles from home when it happened and I got home and shut it off. I put the airbox back in today and everything works fine, so at least I didn't break anything.
I don't think I will use it again unless I have a good way of holding it on there. The clamp seems to slide off the tighter you put it on. But anyway, how is yours working and do you have anything keeping it on?
But I still want to know how yours is working eason.
Just get the K&N panel filter for now. K&N called me last week and wants to borrow my car to do a FIPK kit (what they call their cold air intake kit) and I said yes. That will be designed and tested by K&N on a dyno and that's probably your best bet for cost and power although it may take a few months.
Have you noticed anything in the Buttdyno since you put the K&N on?
BTW, what kind of Buell do you have? Ive got a Harley Road King, but have driven numerous Buells over the years, great bikes!
Anyone of you notice the 2 small hoses attached to the upper air box? I want to make another intake setup the can seperate the bypass valve. Since the hot air release by the supercharge bypass valveis is going back to the intake system; therefore, I want to make a setup that can let the bypass valve to release the hot air to the atmosphere.
this goes back to past discussions on how the Temp gauge should be a primary display... I just dont want to not see it coming.
hey Matt, how much time do we get until the engine boils over after the first Temp warning shows up?
