FYI: Spring drop summary...
Old Oct 7, 2002 | 11:56 AM
KWiK's Avatar
2002 C230 : 2007 C230
Arrow FYI: Spring drop summary...
To make it easier to find, I have summarized the drop from the springs mentioned in the "Eibach Height..." thread.
Brand = Front, Rear, Pad#
Stock = 26.24, 25.25, #1
Eibach = 25.5, 24.5, #4
H & R = 25, 24, #1
RENNtech = 25.25, 24.25, #?
Vogtland = 25.5, 24.5, #4
* This difference in height between the #1 pad and #4 pad is about 15mm(.59").
** RENNtech spings = Apex
It would be nice if we could add the results from Kleemann, Brabus, Carlsson or any others.
Old Oct 8, 2002 | 11:57 AM
patronus's Avatar
2001 C240 / 6-speed
It appears to me that Eibach, H&R and Vogtland have the same rear drop (after calculating the pad thickness difference).
Interesting. Thanks for posting!
Old Oct 8, 2002 | 01:06 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
The Eibach result don't seem work out. I thought Eibach's had the least amount of drop; and you factored in the 1/2 inch additional height with the #4 spring pad.
Old Oct 8, 2002 | 02:28 PM
patronus's Avatar
2001 C240 / 6-speed
YMMV.
Actually, I don't like the measurement technique. These measurements are from the floor to the under side of the wheel well, which has the tire/wheel size combo in play. Even if the same wheels are used, tires' running diameters do vary. 1/4" to 1/2" would not surprise me.
I would rather see the drops measured from the wheel center to the top of wheel well, taking the tire and wheel out of the equation.
Old Oct 8, 2002 | 04:15 PM
KWiK's Avatar
Originally posted by patronus
... I would rather see the drops measured from the wheel center to the top of wheel well, taking the tire and wheel out of the equation.
I have that for my Vogtland, but those measurement were not posted for the other springs, so I went with what was available.
Old Oct 9, 2002 | 03:03 PM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
are the pads for rear only and are they interchangeable ???
Old Oct 9, 2002 | 04:33 PM
KWiK's Avatar
Yes, the pads are rear only.
Yes, you can change which spring pad is on your car.
Old Oct 17, 2002 | 03:17 AM
KompressorBabee's Avatar
2002 White C230 Kompressor Coupe(Black Interior)
Question Springs
hey everyone.. I am thinking of lowering my ride. I know some about springs but not about which brand is best for my car and how much of a drop would be good. gimme sum feedback.. thanx!!
Old Oct 18, 2002 | 02:39 AM
KWiK's Avatar
Re: Springs
What exactly are you looking for? Just lowering? Stiffer ride? Anyway, do a search, there are plenty of threads on springs for your car.
one of the search results
Old Dec 26, 2002 | 01:42 PM
ricoh64's Avatar
'99 E 430 , '05 E500
H&R vs Voghtlnds, has anyone had a ride comparison on a w210?
Old Dec 26, 2002 | 07:13 PM
KWiK's Avatar
I don't think any of the W210 owners on this board have tried the Vogtlands. I have them on my C230K and would say they are not quite as stiff as the H&R. I think it varys by car model because some of the VW guys say the springs are much stiffer than the H&R. For the price, it can't hurt to try them.
