2006 C230 OBD Link Problem?
Old Jul 1, 2007 | 10:48 PM
Sanny's Avatar
06 Granite Grey c230
Hello:
My check engine light went on last night and I have about 28K miles on it.
It's kinda a pain to go into the dealership even though its under warranty so I went to Autozone to see what the code is and to clear it.
I got the OBD II and plugged it in, it said "LINKING" but said could not link. Anyone know what I am doing wrong? I had the switch in both 0 position and 2 position. Still would not link to read the code.
Please help if you can,
Sanny
Old Jul 4, 2007 | 08:31 AM
eunosracr's Avatar
2006 C230 Sedan
I have tried tons of these scanners with my 2006 c230 and none have ever worked.
Old Jul 4, 2007 | 08:45 AM
benzmodz's Avatar
W203 slightly modified
Originally Posted by Sanny
Hello:
Sanny
The scanner needs to be compatible with CANBUS-D and most are only rated for CANBUS-C.
The reason for the change was for a speed increase.
Old Jul 4, 2007 | 02:33 PM
Sanny's Avatar
the next day, i went to a differnt autozone, but used a different scanner. it started doing the same tihng again about "link failure. try again?"
so i dont know i just hit yes again, and somehow it worked! it said clear code? and i was so happy it linked i just hit clear and the light went off! i didnt even get a chance to get the code of what was wrong. i beleive it was a misfire cuase i had the a/c on after a really long time and it was causing the car to be really weak at idle.
but anwyas all is good now.
so maybe just hit yes again and it may work!?
Old Aug 29, 2008 | 09:22 AM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Do you know the specific ISO protocol number of each version, C and D?
I'm searching for a interface for newer cars...
