Servicing Outside Normal Servicing Windows/Shifter Stifness
Awaiting a new arrival...
Servicing Outside Normal Servicing Windows/Shifter Stiffness
Anyone done an oil change/tranny fluid change to their C230 outside of the normal service windows? Trying to decipher how much hassle its going to be with the dealer going outside the normal service interval.
For reference, my 2002 C230 coupe is 6 months old and now has approximately 2400 miles on it. I like to freshen my fluids before winter on all of my cars.
I am hoping a tranny flush improves the horrific feel of the shifter...I thought it was supposed to get better with time, but it is only getting worse, in my opinion. You cannot shift from 1-2 when the car is anywhere short of being fully warmed for a good 15 minutes at least. Anything less and it grinds horribly. (This is with the 6spd)
Thanks.
Thanks.
The dealer will have no problems with doing service outside of when the FSS says to do it. They will be quite happy to present you with the bill for doing it, however.
From your description, I don't think changing the tranny lube is going to help. It sounds like the problem is more serious.
C230 coupe 6sp
Welcome to the world of crappy MB manual transmissions. They have changed my fluid twice, put a new 2nd gear syncro in, and replaced the clutch slave cyl and throwout bearing. It still shifts like crap from 1st to 2nd. It is a very common complaint, that MB can't fix. Make sure they have done the shifter update, and checked the fluid level. Other than that, do like me and wait for the G35 coupes to come out
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Audi S4
speedfrk - were you ever able to convince them to change out the linkage to a C7 part? I think I will talk to mine about changing fluid and doing the update, and if that doesnt work I'll just bite the bullett and pay for the C7 thing myself (and have it done at an independent shop).
Originally posted by Lynn
Since you are having so many problems and there is a service bulletin it should be a warranty item.
C230 coupe 6sp
Originally posted by AndrewK
speedfrk - were you ever able to convince them to change out the linkage to a C7 part? I think I will talk to my about changing fluid and doing the update, and if that doesnt work I'll just bite the bullett and pay for the C7 thing myself (and have it done at an independent shop).
Totita, they should be able to pull up the bulletin at the dealer if you call them. It is actually 2 different things-one is the fluid level, and the other is the linkage update.
Audi S4
I think my problem is mainly about about cold weather. Shift quality was not great during the summer but I have noticed a considerable worsening and an occasional grind into second in the minutes following a 'cold' (maybe 55 degrees) start. I think I'll call tomorrow and schedule and appointment for the fluid/tranny update.
C230 coupe 6sp
Andrew, your problem sounds exactly like mine. It is worse when cold, and you get occcasional grinding going into second. My problem is that it is occasional enough that I can't get it to do it when the car is in the shop. But if you drive it over the course of a couple of days, you will get the grinding several times. The other problem is that they drive so few of these 6sp cars, they don't really even notice it when it happens. Heck it took me a couple of days when my car was new to notice it myself since I wasn't familiar with the car.
2003 C230K, 6 spd, Brilliant Silver, C-5, C-7, CD changer
https://mbworld.org/forums/showthrea...s&pagenumber=3
Getrag apparantly has some serious quality problems and MB doesn't want to officially admit it. Failure rate is way to high.
Who would've thunk MB couldn't get a manual trans right after all these years...
