Ignition Coil
Then after do more research we found out that the ignition coil went bad
Now I saw many treats for C240 indication similar problem and dealer not even cant figure out...which is sucks..
My question is this problem only occur most of the time for C Class?
Due I have ML430 and we knew most of the problem is bad MAF...
Do you guys know what is most significant change once inginition coil going bad...thank s for the input....
