Help needed! C320 manual slips out of 1st gear
I took it to the dealer and they made a shifter link adjustment ($300), which did not fix the problem. Since they have not seen the problem they told me that they can't do anything else to fix the problem. Just bring it in when it happens.
Has anyone had this problem, or know what could be wrong?
To me it sounds like 2 things, the tension in the shift mechanism; or a bad dog gear which could be caused by weak internal springs or worn ***** to hold the dog position as it slide and not hold in its latched position.
I am sure this sounds Greek to you. I've rebuilt a couple of Triumph sportscar gear boxes in my time and actually is quite simple once you understand the dynamics in how it works.
The later series 6 speed transmission (reverse gear to the left and forward) was supposed have cured this problem. I am not sure of the transition date from old-style transmission to new; I think around 2003?
I had this problem on my 2001 C240, happened about once a week or so, same symtoms, except mine was 2nd gear... Last week I lost 2nd gear completely, and now I'm looking at a major tranny repair.
I'll repost more info if I can find someone who'll tear into my tranny without it being a $3k repair bill... If I can't find someone who'll do it for $1500 or less, I'm parting the car out.
Decide im going to put this thing up for sale when i get all the repairs taken care of (drivers door lock pogo, tranny issue!!, and sway bar links)
Early model C240 sports (2002) just have too many reaccuring problems.
