Folding Mirrors Thread - All You Want To Know
#176
NA
W203 Electric Folding Frames Connectors
Mr CitronC230K_03:
I am sure Mr Sunman will say "the dealer will make a connector"... as he is the master "make" and do what is necessary to make things work ... however... hmm... the connector has an specifc male-famale adapter... so wiring each little wire will probably be more expensive... if possible than just getting the right part No.
Just wait until you get all your parts, chances are you will see that you worried about nothing; if the parts had the short connector AND they were shipped with their corresponding wiring harnesses.
I will post later on the pictures of the other set I have which have the short connector and additional harnesses.
Wiedermann
Originally posted by CitronC230K_03
so a shop just made a connector for you or did you buy one? personnally id rather have an MB cable. just wondering what i need.
Wiedermann
#177
1 Post
2003 Citron Green C230KMT
wiedermann, its just the way i am. i get that way over everything, especially my work. everything has to have its time and place. obsessive complusive disorder at its best.
#178
I think he said most 02s dont need the cable, the rest do...not 100% sure though.
Erik
#179
Former Vendor of MBWorld
some slow@$$diesels
I didn't say the fusebox needed to be removed...I said that the fusebox COVER needed to be removed after which the clips that hold the headlight switch can be unclipped from behind (after the torx20 in the bottom of the switch is removed offcourse).
As mailed, douglas, please be calm...the mirrors I send out always come with wiring up to the control unit in the door (except for tifosiv's set - but he got the adapter harnesses shiped later as well)...in your case you will have 2 adapter harnesses to put aside...
greetingz,
greetingz,
#180
NA
Mr CitronC230K_03:
See???
Nothing to worry about man!
W203 Electric folding mirrors with additional short harness
W203 Electric folding mirrors with long harness attached to frames
Wiedermann
Originally posted by MBenzNL
...As mailed, douglas, please be calm...the mirrors I send out always come with wiring up to the control unit in the door (except for tifosiv's set - but he got the adapter harnesses shiped later as well)...in your case you will have 2 adapter harnesses to put aside...
greetingz,
greetingz,
Wiedermann
#181
1 Post
#182
NA
W203 Electric Folding mirror frames final...
Front look with the mirrors folded
Driver's side
Driver's side/Passenger side
Dashboard mounted Light control switch with additional buttons to control electric folding mirror frames
W203 Electric folding mirrors with long harness attached to frames used on this installation
Xenon foglights
(Mr Sunman.. you might remember the chemical compound in the license plate from your phisiology-cardio classes way back when in 2 yr in med school ...or you don't remember???? nahhh... the other cars have license plates with the other resulting compounds to balance the Ph )
Some pins that I saw at the dealer today
Wiedermann
Driver's side
Xenon foglights
Wiedermann
#184
NA
Mr. CitronC230K_03:
Yes. As I mentioned before, the programming was done by the dealership... so what took place, I am uncertain
Wiedermann
hey wiedermann,
did you get the folding feature set when you lock/unlock you car. if so do you have the settings?
hey wiedermann,
Wiedermann
#186
NA
Electric Folding mirrors
Mr CitronC230K_03:
I have confidence your dealer will be able to do the job for you
Cheers!
Wiedermann
worst comes to worst i may have to drive up to your dealer for a service appt. if mine cant figure it out.
Cheers!
Wiedermann
#187
1 Post
i dunno, when i tried to have the norway setting activated on my car they needed the step by step instructions which i needed to provide. i provided and got it set!
#188
NA
WHAT?
Wiedermann
#190
1 Post
c230 kompressor
#191
1 Post
your telling me. thats why i no longer go there, aside from the crappy honda rentals, slow service, long wait for appt's, and not very good service. that and i dont live in san diego area anymore!
#192
1 Post
c230 kompressor
#193
2015 E250D
when i was at the dealer, i used the DAS system and the auto folding feature was not in the Door Control modules or the Insturment cluster settings. You may have to look elswhere. THere are several modules in teh car. I think the DCM module has this feature according to Mark.
#194
1 Post
well time will tell. when i take my car in for the programming ill see if they can atleast track what needs to be done so it can be posted for further use. i may go to wierdermanns dealer, or maybe penske in claremont. mbtech208 works there, maybe he can help. ill ask them to check the DCM as Mark said.
#195
NA
Mr CitronC230K_03:
As Mr sunman said:
I am unsure what was done, however, as I mentioned to you before, if you have someone you know, better go there.
There is a good chance that my dealer "may/will" charge you, and charge they do very sweetly when they want... (I am a customer and I complain a lot... but I don't know if using "that" technique will get "your" auto folding frames programmed)
Cheers!
Wiedermann
Cheers!
Wiedermann
#198
1 Post
sunman, those look great. did you install your yourself. i installed my switch but the rest im having done forme. did you get your convenience feature programmed?
#199
2012 CLS550
Looks sweet!
Do they make kits for these for the W208? I'd love to get some. Does it have an auto feature where the mirrors fold in when you turn off the car and they fold out when you turn it back on?
Cheers,
Dominik
Cheers,
Dominik
#200
1 Post
Originally Posted by Machsurfer
Looks sweet!
Cheers,
Dominik
Cheers,
Dominik
